Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 03-30-2007, 08:40 PM   #1
Well, He asked for it.
WebDog's Avatar
Severity 2 navigation zoon vertical lines
What version of StreetDeck is this bug report for?
1063
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
when zooming every other level has vertical lines and the map is completely unreadable.
2005 VW GTI MKIV - SOLD
WebDog is offline
Advertisement Sponsored links
Old 04-06-2007, 05:38 AM   #2
Think this is relatede to Mappoint 2006 data. I get similar issues with the europe version of SD, it can be temporarily resolved by toggling the virtual earth on and off.
(HTH)
geeky_hawkes is offline
Old 05-31-2007, 11:19 PM   #3
_
Any updates on this in the new release? Still having these problems?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 06-02-2007, 06:39 AM   #4
I certainly am still having display issues with the nav and i feel these vertical lines are related to my loss of all map imagery in 1.0.8.1.
An update on how things are going would be good
Old 06-25-2007, 08:28 AM   #5
_
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
Old 06-28-2007, 09:58 AM   #6
_
Please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
Old 06-29-2007, 09:52 AM   #7
I have retested with 1.0.9.8 and oweing to the fact that my nav projection isnt fixed I guess this issue is still present as well
Old 06-30-2007, 09:00 AM   #8
_
Chuck/Adam - updates?
Jan Bennett
Old 07-03-2007, 10:28 AM   #9
I have done some research on the graphics cards both of you are using. This seems to be an issue with map point and a SIS graphics cards you are using. The jetway J7F3 and the Mirage are using this same SIS processing. You could check for the latest driver updates and see if that fixes the issue.
StreetDeckAce is offline
Old 07-03-2007, 01:15 PM   #10
I am running the latest drivers downloaded direct from SIS.
Old 07-04-2007, 12:51 AM   #11
WebDog's Avatar
I have had my system out of commission for a while but running 1.0.6.3 the issue is not there anymore...
I do know that i let the Windows Update install the video drivers, Maybe the drivers from MicroShaft are more compatible then the SIS?
I will test with 1.0.9.8 tomorrow afternoon and report back if the issue is still gone.
WebDog is offline
Old 07-04-2007, 01:01 AM   #12
_
WebDog - it would be great if you could report back either way and let the QA team and developers know your results.
Thanks for the feedback!
Jan Bennett
Old 07-05-2007, 11:54 PM   #13
WebDog's Avatar
It does appear to be caused by video drivers, now that i went back to SIS drivers the issue came back...
I will try some other drivers and see if i can find ones that work better.
WebDog is offline
Old 07-07-2007, 11:15 AM   #14
Is there any movement from the SD guys on making SD more compatible with the SIS drivers?
Webdog where are you looking for alternate drivers for the SIS cards?
Old 07-08-2007, 07:59 PM   #15
We are going to start carrying the Jetway motherboard line on the mp3car store. We are currently looking for a solution. This is really more of a SIS issue due to all other graphics processors handling 3D graphics fine. We hope to have a solution as soon as we have a SIS board to test on. until then your logs and feedback will help tremendously.
Closed Thread
Centrafuse RC3 Release Notes veetid Centrafuse 0 08-20-2006 11:09 PM
Destinator Ranked No.1 in UK Handheld Navigation Market ccsnet GPS 1 10-18-2005 10:24 PM
Voice activated navigation for routis! 0l33l PowerVoice 352 10-03-2004 03:39 AM
Vertical colored lines on screen?? HELP AlphaFox LCD/Display 13 10-21-2003 08:06 PM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 02:16 AM
