Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 04-11-2007, 05:11 PM   #1
irdrive is an unknown quantity at this point
TV module not working
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
TV stopped working after the 1.0.8.1 update. I think the problem is with the latest update as it worked perfectly before the update. The Music and Radio modules work fine. It seems like when I press the TV button the module doesn't even initialize. The same page just refreshes. Maybe there's an error where there is no command to start the TV module when the button is pressed.
Infill T3 with Infill Station
2007 Hyundai Sonata
irdrive is offline
Old 04-12-2007, 03:43 PM   #2
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
The TV hardware is not started when launching the module because of how modules are launched in the new update. If you start TV by binding the TV function to a gesture or something else, it should work now.
This will be fixed in the next update.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 04-13-2007, 02:51 AM   #3
Thank you. I used the gesture for TV, and voila, the TV module is back alive. I was little scared when the TV didn't work, because I spent alot of time installing the TV antenna on my rear window. It's my first time with a TV in a car but the picture quality is quite good with the powered antenna.
2007 Hyundai Sonata
irdrive is offline
Old 04-21-2007, 01:09 PM   #4
sharpmat007's Avatar
sharpmat007 is an unknown quantity at this point
Same issue and solution works. Chuck, hit me up if you need me to test the update prior to release.
Mitsubishi Eclipse 2006 GT
Infill T3 running StreetDeck
sharpmat007 is offline
Old 04-21-2007, 01:23 PM   #5
rburhum's Avatar
rburhum is an unknown quantity at this point
Does that mean that if I unbind the gestures for navigation that SD won't try to initialize go trough the autodetection sequence of my GPS receiver and get a hold of it?
rburhum is offline
Old 06-21-2007, 12:29 AM   #6
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
RedGTiVR6 is offline
Old 06-25-2007, 09:22 AM   #7
_
Jan Bennett
Old 06-28-2007, 10:46 AM   #8
_
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
Closed Thread
