System Blue screens right after Streetdeck starts
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Installed new 1.0.8.1 update and Streetdeck stopped working right.
uninstalled and reinstalled -- same deal.
Get BSOD with
PAGE_FAULT_IN_NONPAGED_AREA
igxpdx32.dll is the offending driver (graphics)
STOP 0x00...050
Intel 945gm chipset, driver version 6.14.10.4785 (latest available on their site)
I noticed as the program started to load that there were 2 lines or so of the taskbar showing at the bottom of the screen -- this is also new to this revision.
Prior to the reinstall I was able to get into SD, it loaded right into NAV module and appeared to work but if you try to navigate out of the NAV module the screen you were going to shows up for a sec, slightly distorted background (behind buttons), and then BSOD. Same BSOD everytime.
I'm rendered useless now.
