The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Thread Tools Display Modes
Old 04-12-2007, 12:31 AM   #1
rburhum's CarPC Specs
rburhum's Avatar
Vehicle: 2002 Audi TT Roadster / 2000 Isuzu Rodeo
My Photos: (0)
Can't tell SD not to open GPS COM port
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
no
If no, please describe your system here.
winxp sp2 / SD / T3
Please provide any relevent information regarding the issue you have encountered.
Mappoint navigation kept crashing on me so I decided to use SD with iGuidance instead. I uninstalled mappoint and installed iguidance. For some reason, everytime SD starts up, it opens the COM port for the GPS, even though *I don't want that* because it gets in the way of iguidance. Clicking on navigation settings does nothing since mappoint is not there. Resetting SD settings does nothing. How can I tell SD *not* to open the COM port?
rburhum is offline
Sponsored Links
Old 04-12-2007, 06:50 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Did you set the COM POrt for GPS in SD to DISABLED?
Another solution is to use a COM port splitter like XPOrt or GPSGate.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
DarquePervert is offline
Old 04-12-2007, 09:29 AM   #3
rburhum's Avatar
My Photos: (0)
where is the GPS COM port setting stored in SD?
That's what I am trying to do. Keep in mind I already have Mappoint already uninstalled. I can't access the GPS settings in SD; clicking on "Navigation Settings" does nothing *once MapPoint is already uninstalled*.
Another thing I tried was to have another application be using that COM port before SD started so that SD would try to open the COM port and fail (since it was being used). I did get an SD error message dialog that said something along the lines of "check your GPS connection settings" (as expected) with 2 options: "Settings" and "OK". Clicking on either one does nothing and sends you back to SD. There *has* to be a registry setting or configuration file that SD reads at startup to figure which COM has been configured for the GPS device; since UI won't allow me to change that once MapPoint has been uninstalled, I should be able to modify that registry setting/file directly. it is not configuration.xml... do you happen to know which one it is?
Another thing I can try is reinstalling MapPoint, change the configuration to DISABLED using the SD UI (hopefully the UI will work once it detects MapPoint is there); this seems "silly" to me though (for lack of a better word).
Although it seems to me that these two software solutions should work (haven't tried it yet, but makes total sense), why whould I have to add virtual COM ports to circumvent the real problem; SD trying to open my COM port when MapPoint is not installed? I just need to know where that setting is stored.
By the way, thanks for the help DarquePervert.
rburhum is offline
Old 04-12-2007, 11:20 AM   #4
Raw Wave
god_of_cpu's Avatar
Vehicle: 2003/Infiniti/G35 Sport Coupe
My Photos: (0)
Run with teh command line parameter -resetconfig and it will reset all the settings to the defaults.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 04-13-2007, 12:41 AM   #5
rburhum's Avatar
My Photos: (0)
no luck
That didn't do it.
I had already tried that before with the "Start->Programs->StreetDeck->Tools->Reset Configuration Data" which as you know pretty much does the same thing you suggested.
So I went ahead and reinstalled mappoint so that the settings were going to be reenabled; they were. I could then set it to disabled and the COM port was released *for that SD session*. I then closed SD again, and the next time I reopened it, SD tried to outsmart me and re-detected the GPS port and set it to COM 1 once again starting the problem all over.
It then ocurred to me that if I went ahead and changed the COM port settings, closed SD, uninstalled mappoint, that SD wouldn't try to autodetect the GPS again.
Nope, I was wrong.
To SD, it doesn't matter whether Mappoint is installed or not, it always goes through the autodetection sequence for the GPS. That seems like a bug to me.
I guess my only solution will be to go with the virtual COM ports... maybe I'll try that tomorrow ... *sigh*
rburhum is offline
Old 06-20-2007, 11:37 PM   #6
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 06-25-2007, 08:19 AM   #7
_
My Photos: (90)
Jan Bennett
Old 06-28-2007, 09:37 AM   #8
_
My Photos: (90)
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
Attention Newbies! Everything (almost) you want to know about GPS (Part 1) Bugbyte GPS 55 06-08-2008 08:54 PM
SD Navigation just does not work. rumy StreetDeck 54 03-10-2007 07:11 AM
SDAL GPS Map Access Navtech Open Standard Thred ccsnet GPS 61 09-08-2005 03:01 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
