Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 04-16-2007, 02:27 PM   #1
geekinsc's Avatar
geekinsc is on a distinguished road
Windows taskbar and notification bubbles show up on top of streetdeck interface
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Since upgrading I have noticed that when streetdeck launches, I see several windows yellow bubbles in the right corner.. things like "wireless networks detected", "updates are available", etc. These bubbles "flash" at what appears to be the same rate as the frames per second direct x refresh rate.
I have my taskbar set to auto-hide, but if I turn that off I see the status bar as well.
Another user has reported this same issue in the forums.
2006 Audi A4 S-Line. 70% Complete.
My Worklog
geekinsc is offline
Old 04-16-2007, 08:28 PM   #2
knubile's Avatar
knubile is on a distinguished road
Mine acts like that too. I also noticed, if I look closely SD is off to the left by a few pixels. I can see the desktop behind it.
It seems like its not actually running as a full screen app anymore.
knubile is offline
Old 04-21-2007, 08:22 PM   #3
carputerwiz is an unknown quantity at this point
I had that problem too but when i updated to the 1.8.1 version it was fixed. hope that helps.
carputerwiz is offline
Old 04-23-2007, 04:49 AM   #4
spaceskater's Avatar
spaceskater is on a distinguished road
I have the exact same thing. My taskbar is visible and it does look off by a few pixels to the left. If I have a bright colored window behind I can see a thin white line on the right.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline
Old 05-14-2007, 08:48 AM   #5
geekinsc's Avatar
Any Updates? Have you been able to reproduce this bug?
My Worklog
geekinsc is offline
Old 05-14-2007, 09:07 AM   #6
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
No, we haven't been able to duplicate this issue yet.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 05-14-2007, 11:07 AM   #7
I had the exact same problem but reinstalling SD fixed it for me! I did a clean install.
Old 05-14-2007, 04:00 PM   #8
StreetDeckAce is an unknown quantity at this point
Windows BUG!
Windows XP loves to bug you about every little thing. Here is a registry editor that will eliminate some of the balloons from popping up. Right click on the link and save it to your desktop for easy integration.
Hope this helps! Let me know if you have any other questions.
StreetDeckAce is offline
Old 05-14-2007, 04:17 PM   #9
VmtSquad's Avatar
VmtSquad is an unknown quantity at this point
Remove bubbletips in windows!
If I understand your problem here, there's a problem when the bubble tips of windows "pops" it apears on top of ur apps.
If you want to remove or disable the "Bubbletips" in windows you simply have to add a registrykey in your REG KEYs.
Here's the step by step...
1.Click on Start and then on Run.
2.In the open box type regedit and then click OK.
3.Click on the plus (+) next to HKEY_CURRENT_USER.
4.Click on the plus (+) next to Software.
5.Click on the plus (+) next to Microsoft.
6.Click on the plus (+) next to Windows.
7.Click on the plus (+) next to CurrentVersion.
8.Click on the plus (+) next to Explorer.
9.Click on the folder Advanced. This should give you a long list of items on the right window pane.
10.Click on Edit, select New, and choose DWORD Value.
11.Name the new DWORD Value EnableBalloonTips.
12.Double-click this new entry, set the value to 0.
13.Fill in the dot next to Hexadecimal.
14.Close the Registry Editor and reboot the computer normally.
You have now disabled the balloon tips in the system tray.
I hope this helped some one since so many people had the same error.
VMTSQUAD
VmtSquad is offline
Old 05-14-2007, 06:44 PM   #10
will2710
And for those of you scared (or too lazy) to go into the registry, grab Tweak UI from Microsoft to disable balloon tips (under taskbar and start menu).
I don't have any experience with SD, but you may want to disable applications from stealing focus (general > focus).
will2710 is offline
Old 05-14-2007, 06:50 PM   #11
cheap custom title
JC-S60's Avatar
JC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really niceJC-S60 is just really nice
The two posts above just let you do manually what is done when you import the .reg file Chuck posted...
JC-S60 is offline
Old 05-14-2007, 06:52 PM   #12
cheap custom title
JC-S60's Avatar
VMTSQUAD
Back in the day, 0 was the same in HEX as it was in DEC, must be that modern stuff that I'm too old for
JC-S60 is offline
Old 06-01-2007, 12:05 AM   #13
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
issue considered resolved.
Jan Bennett
RedGTiVR6 is offline
Closed Thread
