04-22-2007, 09:26 PM
#1
Vehicle: 2000 VW Jetta TDi
Streetdeck pauses for long periods of time on startup
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
This only happens every four or five times I resume from hibernation. Streetdeck will just show up as a black screen when Windows resumes, and will stay like that for about 45 to 60 seconds. I think I may have figured out the problem though, and I'm sure it wouldn't be to hard to fix with a quick update. I noticed that every time this happens, the songs in the queue get multiplied a few times. After restarting one or two more times, the growth is exponential and causes the system to hang for long periods. I'm not really sure what could be causing this in SD, but it could have something to do with the randomization algorithem, since it namely happens with random turned on. I'll get a report in next time it happens.
Build Two:
Planning: [==========]100%
Purchasing: [=========-]90% (Other 10% is still in Beta)
Design: [=======---]70% (Still trying to get into my schools protolab)
Install: [=========-]90% (Still working on screen beisel)
04-23-2007, 05:00 PM
#2
Vehicle: 2001 Toyota Tacoma Doublecab
I am reporting that I also encounter this issue.
This is also for 1.0.8.1 and my system is listed in my profile.
I found that every time I resume from sleep, the queue is multiplied. If I have nine songs when I go into sleep there will be 18 when I resume, all double of the original 9. The next time it will be 36 and exponentially larger. When that queue contains several thousand of the same 9 songs, the startup is very slow.
I do not have repeat or random play turned on.
04-24-2007, 01:45 AM
#3
Vehicle: Subaru WRX STi
Queued music gets re-added after resume from hibernation
1.081
yes
It isn't EVERY time, but it is pretty frequent. Let's say I have 11 songs in my queue. If I hibernate, then resume, it has 22 songs (the same 11 put in the queue again). It seems to be when I leave the song playing during hibernation. The last time I paused playback prior to hibernation it did NOT do it.
04-24-2007, 07:17 AM
#4
1.081
yes
I am also having the same issue. queue music list readd after hibernation too. making it double, tripple etc
04-24-2007, 10:48 AM
#5
Vehicle: 2002 Audi S4 - Not quite stock
third.
04-24-2007, 10:51 AM
#6
a different twist on this: I see SD taking a long time (10-20 seconds) at various times when I hit the music button on the main screen, click the album art in the queue view, click artists from the music selection screen, and other music related things.
I've only recognized it in the music modules, but perhaps it occurs elsewhere also. I do not see CPU spike with it, and once it happens, if I then repeat the same functions/actions, it goes quickly as usual. I use the -nodelaycomp and -nodelayload switches every time I run SD.
I have not noticed whether this is related to a large queue or not.
04-25-2007, 08:08 AM
#7
Vehicle: '02 Subaru Liberty RX
me also
04-25-2007, 08:23 AM
#8
Raw Wave
Vehicle: 2003/Infiniti/G35 Sport Coupe
Should be fixed in the next patch.
04-25-2007, 01:57 PM
#9
Thanks Chuck.
Ryan
04-25-2007, 03:36 PM
#10
Great!
I believe that this is the same issue that was posted to and I added to here: http://www.mp3car.com/vbulletin/stre...e-startup.html
Thanks Chuck.
04-25-2007, 10:01 PM
#11
Vehicle: 2001 Range Rover
I get the same type of delays resuming from sleep while in the XM module. Nothing in my music queue. Doesn't happen every time, but maybe 1 out of 5 times.
04-25-2007, 10:23 PM
#12
Happened again. A 13 song playlist got multiplied to a 40600 song playlist. Not fun.
Build Two:
04-28-2007, 11:48 AM
#13
Any mod have any idea what is causing this?
Build Two:
06-20-2007, 11:26 PM
#14
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
please retest on 1.0.9.8 and report back with your findings.
06-25-2007, 08:24 AM
#15
_
BTW - EvilLawn - the Moderators on this forum do not work for MP3Car.com, they are volunteers. They are not responsible for QA or development of StreetDeck nor are they responsible for answering Bug Reports.
| Thread Tools |
| Display Modes |
Linear Mode
