sound does not work right and crashes on TV
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Stock T3 system running through Amp for all sound
Please provide any relevent information regarding the issue you have encountered.
Evertime that I return to SD after Standby or restart I have to go into Vinyledeck and change sound output to 6ch. This happens everytime. If I switch to radio then it goes to stereo sound only(Front channels) then I have to switch it back to 6ch after I finshwith radio and go to another module. If I switch to TV all works fine then unless I switch channels alot then SD stops and goes back to main screen and will not return to TV and also switchs back to 2ch sound. I must reboot at this time to get back to TV or 6ch.(So I do not watch TV.. Takes to much time) Sound has been a issue from the begining. Was hoping thatupdate would fix. Please help.. What else is there for me to try.(Have tried reinstalling OS then SD)
