Update hung on first upgrade from previous verison
What version of StreetDeck is this bug report for?
1.081
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
I ran the update on my development machine and the first boot of SD took about 30 seconds and worked fine. I put it on the CarPC and it locked at Saving Settings (I think that is what it was - seems like it is the last step on the splash screen). Anyway, I opened task manager and it was not hitting the CPU at all. Every 20 seconds or so it'd hit 4%, then go back to 0%. SD was taking about 159 megs of mem and sitting steady so it looks like it was just off in the weeds. I ended the task and loaded it again and it booted up fine with no issues. I know this is isn't reproducable but I figured I'd mention it in case it sheds light on something else...
