StreetDeck pegs the CPU and System Memory
What version of StreetDeck is this bug report for?
1.0.8.1
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
After loading the 1.0.8.1 update, which completed just fine, my system runs EXTREMELY slow. The buttons take forever to display, there is a 1-2 second delay after pushing a button for its function to take place, and the system's speed seriously inhibits its ability to interpret gestures on the touch-screen.
I toggled the system to window rather than fullscreen and was able to get a good look at the Windows Task Mangler. StreetDeck.exe is pegging the CPU and consuming 88,000K+ of memory. I tried running -nodelayload -nodelaycomp with little change. I've also run -resetconfig, but the problem persists.
I ran the 1.0.6.3 update back over the 1.0.8.1 and everything runs great. I ran the 1.0.8.1 update again, which completed successfully, but everything started to creep again. Sure enough, StreetDeck.exe was pegging the CPU and consuming tons of memory all over again.
I've included my log file from the latest attempt at 1.0.8.1.
Currently, I have installed 1.0.6.3 back over 1.0.8.1 until I can figure out why SD is pegging my resources.
Please let me know if anyone has any ideas.
Thanks,
UV7
True knowledge exists in knowing that you know nothing. True wisdom comes to each of us when we realize how little we understand about life, ourselves, and the world around us.
-Socrates
