Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 07-01-2007, 02:44 PM   #16
geeky_hawkes is on a distinguished road
Sorry, im in the uk so not able to call to discuss this issue, however I have made a video attached of the issue "at work".
As far as machine spec, its a celeron 1.6ghz, 512mb ram, sis mirrage graphics 661 card, DX7H/W and DX9s/w, also got an 80gbHDD and running 800x600 @ 60hz in both 16bit and 32 bit (with no change to the problem).
Windows XP SP2, full install with just a few standard tweaks to reduce boot time. As mentioned before this issue was not present in 1.0.6.3 (appart from the vertical lines anyway), but has been an issue in the last two versions of SD.
I will post a link to the SIS site if required indicating some more details about the card.
Hoep this helps as its damn frustrating the nav not working!
Cheers guys
geeky_hawkes is offline   Reply With Quote
Old 07-01-2007, 03:18 PM   #17
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
geeky - you can post your PC specs under your user name if you would like.
See here for instructions: http://www.mp3car.com/vbulletin/anno...r-profile.html
It makes things easier for others trying to help you out.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-01-2007, 05:06 PM   #18
Specs added, hopefully this bug can be fixed soon!
Old 07-02-2007, 09:42 AM   #19
StreetDeckAce is an unknown quantity at this point
Are you using a Europe version of map point since you are in the UK?
StreetDeckAce is offline   Reply With Quote
Old 07-02-2007, 02:55 PM   #20
yes I am running mappoint europe and from the video you can see it works not in full screen mode.
Old 07-02-2007, 03:33 PM   #21
I can't reproduce this issue. I will forward this post to our software engineers to see if they can be more helpful.
Old 07-26-2007, 10:13 AM   #22
_
All involved in this thread - please update to the newest release (1.1.0.0) and report back with your findings.
Jan Bennett
Old 08-02-2007, 08:40 PM   #23
I will as soon s I get my car back from the garage. can you confirm that changes have been made to graphics in 1.10.0 and just out of interest what were they?
Old 08-07-2007, 11:05 AM   #24
_
no changes have specifically been made to this area of the code. However, we still need you to update to the newest release and report back with your findings.
If this issue is fixed by you updating then we don't need to spend valuable time trying to diagnose what's wrong.
Jan Bennett
Old 08-07-2007, 03:55 PM   #25
I understand, as soon as I get my car back I will update and try it
Old 08-20-2007, 10:05 AM   #26
_
When will you have your car back?
Jan Bennett
Old 08-23-2007, 03:24 PM   #27
Should be about a week so I will report back with my findings as soon as i can.
Old 12-02-2007, 12:54 AM   #28
peterfnet is an unknown quantity at this point
I have the same problem. It only happens when I am offline so far. If I connect to the internet and renable virtual earth, tada! I have real maps again. Sometimes I have to restart the computer. Sometimes (while still offline) right after a boot, it doesn't work.
He is spot on with this problem.
I am running 800x480 res on an integrated Intel video card.
peterfnet is offline   Reply With Quote
Old 12-02-2007, 08:29 AM   #29
_
You never reported back, do you have any updates?
Jan Bennett
Old 12-10-2007, 03:19 PM   #30
_
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
iGuidance Hacks pbarrette GPS 47 12-28-2007 04:06 PM
white background in flash location? addertay Road Runner 14 11-06-2007 07:05 PM
Loss of Map "projection" on upgrade 2 1.0.8.1 geeky_hawkes StreetDeck 5 05-25-2007 11:59 AM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
