Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 06-15-2007, 11:05 AM   #16
spiro is on a distinguished road
Quote: Originally Posted by RedGTiVR6 View Post
Spiro -
I dont have that option - in that screen or in the video settings -
im attaching a screenshot
I havent had that option (fps) since 1 0 8 7 I think!
BTW I just had a thought......(yes I m capable)
Is it possible that the "updater" doesnt work right?
What im saying is that maybe the updater depends on specific settings and /or running modules
maybe thats why we all get different results even though we all have G4 s
and update with the same version
which brings me back to what I had posted sometime ago
What if we can have an updater that resets everything to default settings and then update and test
We wouldnt want to loose our personalized settings of course so I suggested that maybe we can have a little module/ap that saves a "personal preferences file" with all our settings
If we test with default and it works, and then apply our "settings file" and we get bugs, at least it makes it easier to troubleshoot
The only thing wrong with this is that the SD coders have their hands full already but, think of it as investing in the future, built infrastructure that will help them with future updates
spiro is offline
Old 06-15-2007, 07:28 PM   #17
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
You can use -resetconfig to reset your configuration to default.
Config.xml and options.sdo contain all the options for StreetDeck. There is nothing stored in the registry. Just make a copy and restore this file to go to / from your settings and other ones.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 06-15-2007, 07:28 PM   #18
Raw Wave
god_of_cpu's Avatar
You can not change the framerate on the T3 or G4.
Old 06-15-2007, 09:55 PM   #19
pickupthepace is an unknown quantity at this point
Do you want everyone with this problem to try the config reset or just those on the infills?
pickupthepace is offline
Old 06-17-2007, 06:55 PM   #20
StreetDeckAce is an unknown quantity at this point
If you believe the issue occurred after you changed a setting, Any SD user can troubleshoot using this method.
StreetDeckAce is offline
Old 06-18-2007, 03:58 PM   #21
Raw Wave
god_of_cpu's Avatar
This appears to be caused by T3devControl.dll being present in an install on a non-Infill platform. If your not running on an Infill T3 or G4. You should delete the file T3devControl.dll and the problem shoudl go away. You may need to create an empty dummy file in its place to get around the automated installer issues.
Old 06-19-2007, 08:19 PM   #22
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I've just tested this on my laptop with 1.0.9.8.
With this update, I've noticed a bunch of pink text at the bottom that wasn't there before.
Came up with something like 25 notices before SD opened fully.
However, this issue does appear to be fixed now.
As soon as someone else can confirm, I will close this issue.
Jan Bennett
RedGTiVR6 is offline
Old 06-20-2007, 12:28 AM   #23
S4Per's Avatar
S4Per is on a distinguished road
my fps settings and 16x9 vs. 4x3 settings now are successfully saved during standby and restart of SD with 1.0.9.8
S4Per is offline
Old 06-20-2007, 09:38 AM   #24
Raw Wave
god_of_cpu's Avatar
If you didn't delete T3DevControl.dll, you probably should as it still tries to use it if its there, but will fail after a number of seconds and lengthen your start time.
Old 06-20-2007, 10:12 AM   #25
_
Issue closed.
Jan Bennett
Old 08-06-2007, 08:31 PM   #26
pim
pim is on a distinguished road
display format not saved
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Display format under settings->general->display options is not saved. It always starts with "normal (4x3)".
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
no
If no, please describe your system here.
Non mp3car.com Infill G4
Please provide any relevent information regarding the issue you have encountered.
Demo version
pim is offline
Old 08-06-2007, 10:49 PM   #27
_
threads merged. Issue still closed.
Jan Bennett
Closed Thread
V1 Virtual Display : Skinnable Valentine One to PC Software zPilott Software & Software Development 81 10-31-2009 08:19 PM
Planning Phase help for ceiling mounted display HullBreach Newbie 3 04-07-2007 05:31 PM
Centrafuse XLE RC1 Release Notes veetid Centrafuse 0 07-12-2006 04:48 PM
