06-07-2007, 12:40 AM
#1
Display settings not saved
What version of StreetDeck is this bug report for?
1.0.9.6
Please give a basic description of the issue here.
Phone Information
Please list your phone carrier you are using to test with.
Please list the manufacturer of the phone you are using to test with.
Please list the model of the phone you are using to test with.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Change video settings (e.g frame rate from 1 fps aspect ratio from 4x3)
Choose save.
Save to Disk.
Exit SD
Start SD, fps is back to 1fps and 4x3
Please provide any relevent information regarding the issue you have encountered.
Same issue as 1.0.9.5.
06-07-2007, 12:47 AM
#2
Ditto
06-08-2007, 02:01 AM
#3
3rd.
06-11-2007, 09:54 AM
#4
Raw Wave
I need a log, I can't duplicate this.
06-11-2007, 10:01 AM
#5
_
On my laptop and on the G4, when I go into the Video settings from within the settings there is nothing to save.
Is this where the rest of you are going to make these changes?
06-11-2007, 11:53 AM
#6
it's in general - display options. next time it happens i'll send a log.
06-11-2007, 12:00 PM
#7
_
Able to recreate.
Log file from when I made the change and exited and from when I restarted SD attached.
this was on the G4.
06-11-2007, 01:55 PM
#8
4th
06-11-2007, 05:00 PM
#9
Log files
Here a files which should be verbose logs of:
1) start, setting display fps/16x9, save, and exit.
2) restart where settings have not been saved.
06-15-2007, 06:09 AM
#10
This is still not working in 1.0.9.7. Exact same thing as .6. Set to 45 fps and 16x9, exit, reload, and it is reset to 1 fps and 4x3.
06-15-2007, 07:49 AM
#11
_
please provide a log.
06-15-2007, 09:28 AM
#12
Quote: Originally Posted by RedGTiVR6
Able to recreate.
this was on the G4.
G4 here too
how where u able to set fps? I cant see the option (same screen as in your post) no options on the video settings!
06-15-2007, 09:30 AM
#13
On the infill T3 they hard set the fps limits so you dont see that menu. On the T3 I believe its lowered to 15fps...probably higher on the G4 as the video card is better. The milkdrop effect is also removed on T3.
Mitsubishi Eclipse 2006 GT
Infill T3 running StreetDeck
06-15-2007, 09:31 AM
#14
_
Spiro -
06-15-2007, 10:21 AM
#15
2nd
| Thread Tools |
| Display Modes |
Linear Mode
