06-24-2007, 12:48 AM
#1
Night Mode Issue - 1.0.9.8
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
Night Mode Issue
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting. I pick night mode. Please provide any relevent information regarding the issue you have encountered.
It doesnt go to night mode. It goes to it for about 1 second but then it fades back into normal mode.
06-24-2007, 12:51 PM
#2
Raw Wave
Are you running on an Infill T3 or G4?
06-24-2007, 12:53 PM
#3
I get this too... my PC is under my name.
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
06-24-2007, 11:20 PM
#4
Raw Wave
I can't duplicate this, but it might be fixed in 1.0.9.9
06-25-2007, 01:20 AM
#5
I get the same problem on my carPC but is works fine on my laptop for some reason.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
06-25-2007, 09:36 AM
#6
_
bumping to the top after updating all other threads.
06-25-2007, 10:32 PM
#7
I have the same problem. When I try to toggle into night mode it stays there for about a second or two then goes back to normal mode. It does it on my laptop (running demo version) as well. Worked fine before the update.
PC Specs:
Via Mini ITX board w/ C7 1.5ghz cpu, 512mb DDR2, 10.5" samsung touch screen, 60gig SATA HDD, onboard video
- Mike
06-25-2007, 10:41 PM
#8
_
thepunkerguy - you do know you can post your CarPC specs so they show up under your user name, right?
If not, you can find instructions here: http://www.mp3car.com/vbulletin/anno...r-profile.html
06-25-2007, 11:00 PM
#9
Quote: Originally Posted by RedGTiVR6
Done!
- Mike
06-27-2007, 11:37 PM
#10
Hi there,
I just updated to 1.0.9.8 from 1.0.8.1 and I have the same problem. Night mode lasts for about 1 second and then switches back to normal.
Tim
06-28-2007, 12:13 AM
#11
Think we could get some kind of quick fix for night mode or do you have any idea when the next update will happen so we can get night mode back? It would be a bummer to have to wait for a bunch of other stuff to accumulate and be fixed just to get night mode back!
06-28-2007, 12:30 AM
#12
FLAC is for flaccid
Same problem here, appeared after the update. System specs are listed.
A quick fix, as mentioned above (and now below) would certainly be appreciated. Even with the LCD brightness all the way down, daytime navigation maps are pretty blinding at night.
An amateur built the Ark. The Titanic was built by professionals.
06-28-2007, 12:39 AM
#13
I second that! A quick fix is needed.
06-29-2007, 10:53 AM
#14
Same problem here as well!
06-30-2007, 10:00 AM
#15
_
Chuck/Adam - any thoughts on a possible fix?
| Thread Tools |
| Display Modes |
Linear Mode
