Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 06-24-2007, 01:40 PM   #1
bembowe is on a distinguished road
Severity 3 SD freeze when using browse in navigation module - 1.0.9.8 - 1.1.0.9a
What version of StreetDeck is this bug report for?
1.0.9.8 - 1.1.0.9a
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
select the navigation module. click on browse. click on any of the arrows. this freezes up sd and eventually would lead to sd closing. I had the music module playing as well when i was doing this
Please provide any relevent information regarding the issue you have encountered.
bembowe is offline   Reply With Quote
Advertisement Sponsored links
Old 06-25-2007, 09:34 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
bumping to the top after updating all other threads.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-26-2007, 12:42 AM   #3
thepunkerguy is an unknown quantity at this point
This has happened to me several times as well. Not every time, but a lot of the time.
- Mike
thepunkerguy is offline   Reply With Quote
Old 06-26-2007, 08:35 AM   #4
_
the developers need logs. please post your logs so that they can help determine where the problem lies.
Jan Bennett
Old 06-28-2007, 11:03 AM   #5
_
bembowe and thepunkerguy - please post your logs. Without them this thread will have to be closed.
Jan Bennett
Old 06-30-2007, 10:02 AM   #6
_
Adam/Chuck - updates?
Jan Bennett
Old 07-03-2007, 11:39 AM   #7
StreetDeckAce is an unknown quantity at this point
I have had this issue in the past. The development team is working on how to exactly reproduce this issue. Please post your logs and describe exactly what you were doing before SD crashes to help us troubleshoot this issue.
StreetDeckAce is offline   Reply With Quote
Old 07-16-2007, 11:58 PM   #8
_
due to a lack of follow-up from the OPs and no logs, we cannot continue supporting this bug.
If either of you have a log to post, you can reopen this thread and post them. Untill then, we have to consider this a non-issue.
Jan Bennett
Old 08-01-2007, 07:41 PM   #9
SD freeze when using browse in navigation module - 1.1.0.0
1.1.0.0
Yes
Yes
I am reopening this as i do have a log file of the issue. My zipcode is 64117. not sure if it will be relevant but my gps was in this zipcode when it happened. if you need any more info, please let me know
thanks
Old 08-01-2007, 07:53 PM   #10
_
rather than create a new bug report, please just open the existing one in the future. I've merged these two threads. This helps keep all the information in one place.
Just to add, I have used the browse feature on my laptop and in the car without issues.
Jan Bennett
Old 09-01-2007, 12:41 PM   #11
sinister99 is an unknown quantity at this point
1.0.9.8-1.1.0.0
Yes
Yes
SD has only NOT frozen one time while using this feature
sinister99 is offline   Reply With Quote
Old 09-01-2007, 08:19 PM   #12
_
I have used this feature extensively now. On our 6 hour drive to Orange, TX I used it a great deal and never once had it crash on me.
Jan Bennett
Old 09-01-2007, 08:36 PM   #13
This feature almost always freezes SD the first time I click a direction. A couple times I have moved two or three times before it froze.
Old 09-02-2007, 03:43 PM   #14
marchello2000 is on a distinguished road
Same here
I have yet to see this feature work for more than two browse clicks. As soon as I press one of the arrow keys in borwse mode it freezes, I will collect a log as well.
Please increase the priority on this as 3 of 4 does not sound right
marchello2000 is offline   Reply With Quote
Old 09-02-2007, 04:03 PM   #15
mygti02 is an unknown quantity at this point
i am having the same issue. It freezes each time i click one of the arrows in the browse menu.
mygti02 is offline   Reply With Quote
Question About Extending the Navigation Module unreal32 DigitalMods (Scripts / API) 2 09-18-2006 04:24 PM
GPS Marine Navigation with SD? debugger StreetDeck 4 08-07-2006 07:28 AM
SD Fails to initialize Navigation Troy McClure StreetDeck 10 07-14-2006 01:28 AM
Voice activated navigation for routis! 0l33l PowerVoice 352 10-03-2004 04:39 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 03:16 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
