Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 06-27-2007, 11:38 AM   #1
Severity 4 - Lowest Static noise in music after hibernation - 1.0.9.8
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Resume from hibernation. Happens every 4 or 5 times after I resume.
Please provide any relevent information regarding the issue you have encountered.
Every few times I resume from hibernation there is a constant loud static/popping noise in the music. If I restart SD or hibernate again the noise goes away.
MikeD610 is offline
Advertisement Sponsored links
Old 06-30-2007, 09:05 AM   #2
_
Chuck/Adam - updates?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 07-03-2007, 12:23 PM   #3
Are you using the internal sound card?
StreetDeckAce is offline
Old 07-06-2007, 11:57 AM   #4
No, it does have an internal sound card but I am currently using an external Turtle Beach micro sound card.
MikeD610 is offline
Old 07-06-2007, 01:01 PM   #5
Does this popping sound like a digital scratch or a grounding issue hiss. The reason I ask is that with external USB sound cards there is an issue with the number of devices plugged into a single controller which causes a digital popping in the background of music. The other issue could be the targus power supply you are using could be creating a ground loop with your amplifier. The solution is to get a ground loop isolator ($15) or spread the distance between the targus PSU and the amplifier. If these are not the issues can you record the audio and post it for better trouble shooting. Hopefully this helps!
Old 07-07-2007, 02:00 AM   #6
This is more of a constant bad digital scratch sound. This is defiantly not a grounding issue (I worked those out a long time ago :-)). I only hear this problem every few times I resume from hibernation and when I restart SD the problem instantly goes away. When you say there is an issue with the number of devices plugged into a single USB controller, do you mean a SD issue or Hardware/driver issue?
MikeD610 is offline
Old 07-08-2007, 07:47 PM   #7
This would be a hardware bandwidth issue. If you have to many devices plugged into a single USB controller there will be this sound in the background of your external sound card. Do you have another device that SD uses plugged into the same USB hub?
Old 07-16-2007, 10:28 PM   #8
_
MikeD610 - we cannot continue supporting this bug if we do not have any followup.
Please provide some response for us within 24 hours or this bug report will be closed.
Jan Bennett
Old 07-18-2007, 12:33 AM   #9
sorry... Ive been extreamly busey for the last week. I will post more data tomorrow evening...
Thanks again
MikeD610 is offline
Old 07-26-2007, 09:14 AM   #10
_
any updates?
have you upgraded to the newest release? 1.1.0.0?
Jan Bennett
Old 08-07-2007, 10:06 AM   #11
_
Thread closed due to a lack of followup from the OP.
Jan Bennett
Closed Thread
Resume from Hibernation: Music doesnt autoplay? nobb CF Bug Reports 10 07-14-2007 09:31 AM
music becomes static after voice command from iG rcubed3r Road Runner 1 03-19-2007 12:44 PM
Music Organization CoryF Road Runner 6 02-21-2007 11:14 PM
Noise!! AARGH! sq_geek General Hardware Discussion 23 09-21-2004 01:33 PM
need some noise help spyhunter General MP3Car Discussion 6 07-20-2003 10:20 PM
