06-29-2007, 02:46 PM
#1
Hibernate does not function properly - 1.0.9.8
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
Resume from Hibernate does not function properly
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here. Infill T3 Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting. When I turn of the car power the T3 closees as usual. When I turn the car back on the T3 turns on as usual acting as if it is resuming from hibernation. Once fully awake from hibernation it goes into shut down and shuts itself down. I then have to manually power up the T3 via the power button Please provide any relevant information regarding the issue you have encountered.
This only happened once I upgraded to latest version of SD. I can manually close SD into hibernate and it works fine.
Reason: title unclear
06-30-2007, 02:32 PM
#2
Raw Wave
Vehicle: 2003/Infiniti/G35 Sport Coupe
Is your shutdown option set to hibernate in shutdown settings? Does it work if you set it to standby instead?
07-01-2007, 03:16 PM
#3
Vehicle: 2006 VW Passat 2.0t
Resume from hibernation triggers a full restart (VISTA) - 1.0.9.8
1.0.9.8
Phone Information
Please list your phone carrier you are using to test with.
N/A
Please list the manufacturer of the phone you are using to test with.
N/A
Please list the model of the phone you are using to test with.
N/A
Yes
Yes
1. Streetdeck is open and playing XM
2. Turn off the ignition
3. Carnetix P2140 running PSUMoni successfully sends the pc into Hibernate via USB command.
4. Come back to the car later, start it, initiate resume from hibernation
5. PC resumes, goes to the desktop, then (approx. 5 secs after desktop appears), before Streetdeck is able to resume, the pc shuts down and restarts.
6. Upon restart, Windows gives the message about shutting down unexpectedly.
Please provide any relevent information regarding the issue you have encountered.
If I turn off the ignition WITHOUT SD running, the pc will resume from hibernation successfully with no issue.
07-02-2007, 06:30 PM
#4
I switched it to standby and it still does the same thing oddly enough.
07-03-2007, 12:52 PM
#6
I think I might have solved this one. I disabled Hibernate and rebooted a few times and tested standby to no avail.
I then re-enabled hibernate and the in advanced settings made sure the settings for power button and sleep button both were set to hibernate. The I set SD back to hibernate.
I have tested it twice today and it's worked properly both times.
07-04-2007, 09:50 AM
#7
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
threads merged.
Thanks for the link.
07-06-2007, 09:31 AM
#8
_
vitaminR - can you confirm that this worked and still works?
07-16-2007, 10:55 PM
#9
_
vitaminR - we need confirmation before we can continue.
If I have not heard back within 24 hours, I will have to close this bug report.
07-26-2007, 09:10 AM
#10
_
thread closed.
| Thread Tools |
| Display Modes |
Linear Mode
