Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 08-02-2007, 04:00 PM   #16
Nola111's Avatar
Nola111 is an unknown quantity at this point
If you haven't filled out your CarPC specs in your Profile, you need to list them in the bug report. Most importantly, your sound card and operating system is needed here for this particular issue.
Nola111 is offline   Reply With Quote
Old 08-02-2007, 06:03 PM   #17
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Anyone else able to recreate this issue?
And to back up what Nola111 has posted (thanks Nola111) - you answered 'yes' to the carpc specs thing, but you don't have anything listed there.
We need this information and most likely a log file as well before we can go any further.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 08-03-2007, 11:50 PM   #18
Sinabl is an unknown quantity at this point
See above.
Sinabl is offline   Reply With Quote
Old 08-04-2007, 09:22 AM   #19
_
Sinabl - thanks for the update. This thread might be of interest to you:
http://www.mp3car.com/vbulletin/anno...r-profile.html
Jan Bennett
Old 08-04-2007, 04:01 PM   #20
Nola111's Avatar
Sinabl, are you able to mute/unmute the XM audio in Windows' sound mixer?
Old 08-06-2007, 05:58 PM   #21
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
Have you selected the proper input in XM settings for your sound card?
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 08-07-2007, 10:52 AM   #22
_
sinbal - we need an update to keep this bug report open.
Jan Bennett
Old 08-07-2007, 07:50 PM   #23
Yes, the proper settings are selected. Yes, i'm able to unmute/mute line in and wave out using the windows audio mixer.
Let me play around with it more and i'll provide more info.
Old 08-11-2007, 10:17 PM   #24
It's erratic. Sometimes XM will stop and allow me to play music, but then when i go back to XM, it wont switch to it. Other times, XM will play and music wont (since the waveout is muted) and XM wont stop playing no matter which song i tell it to play. At least, XM should stop playing in this case.
Any updates on the bluetooth GPS issue from my other post?
Old 08-13-2007, 11:39 AM   #25
Aaron3262 is an unknown quantity at this point
I have a similar issue in another thread, that once I select XM the only way to stop it is to toggle the always mute checkbox in the settings. Otherwise when I switch modules XM continues to play. However when I switch from any other module to XM the music stops and XM plays it is when I try to go from XM to anything else.
Aaron3262 is offline   Reply With Quote
Old 08-15-2007, 09:42 PM   #26
Yay, im not the only one then that has this problem.
Old 08-16-2007, 10:35 AM   #27
_
This is not just a Vista problem. I'm able to recreate it here on my laptop now that I have an XM Direct and USB adapter.
I'm going to update the thread title to remove vista from it so we can be sure this is pushed up on the priority list as it's VERY annoying.
Jan Bennett
Old 08-16-2007, 08:56 PM   #28
StreetDeckAce is an unknown quantity at this point
I have talked with chuck on this issue and knows the issue behind this but we are working on a work around that will work for all sound cards. No ETA yet.
StreetDeckAce is offline   Reply With Quote
Old 08-18-2007, 12:37 PM   #29
Sounds good, I'll be looking out for the fix.
Old 08-18-2007, 03:49 PM   #30
Nola111's Avatar
Just want to add that even though this issue might not be exclusive to Vista, the reason that it doesn't work in Vista is a totally different reason than it not working in XP. Vista's sound routing is totally different than XP. In XP, you have a playback mixer with all available channels for listening, and a recording mixer with all available channels for input. In Streetdeck, the satellite radio settings give you a choice of all your available Playback channels... you choose the one your sat radio is plugged into, and SD knows to mute/unmute that channel when entering/exiting the sat radio module.
Vista's mixer, however, is totally redesigned. Because of it's new design, the choice for which playback level to mute/unmute doesn't even show up as an option in SD's sat radio settings. This is because in Vista, your Playback choices are whatever different soundcards you have available to your system. In XP, the playback mixer has just the playback levels related to ONE soundcard showing at any one time. In Vista, you choose what soundcard to output all sound to, but then you have to then go into the properties of that sound card to get to the different playback levels. They are buried, so SD can't "see" them.
I will post some screenshots shortly to further illustrate my point.
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 03:48 PM
I have a few questions regarding sound output AzzKicker Newbie 12 02-06-2004 10:49 AM
XM-PCR Sound / Digital output MeanGT General Hardware Discussion 1 12-23-2003 03:50 PM
Sound Input / Output / Interference leesilk General MP3Car Discussion 6 06-01-2003 12:47 AM
mpxplay with awe 64 very little sound output RWAudio Software & Software Development 3 06-12-2001 08:49 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
