Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 08-18-2007, 07:20 PM   #31
Nola111's Avatar
Nola111 is an unknown quantity at this point
Here are the screenshots:
The first is XP. Everyone should recognize this. The mixer shows all channels currently available for playback. All of these channels show up as choices to pick from in Sat. Radio Settings for where my sat radio hardware is plugged into. In the first pic, the channel called "Line" is where my sat. radio is plugged in. In SD, I have line selected in Sat. Radio settings, and it mutes/unmutes correctly as I enter/exit the sat. radio module.
The second pic is Vista's playback screen. You can see that I have my soundcard "Speakers" for Creative Xmod, selected as the default. The problem is that only what you see here in this screenshot is what is available as options in Sat. radio settings in SD for what the sat radio hardware is plugged into. You can see that there is no choice there for Line. On to the third screenshot...
The third pic shows what you see if you click on Properties for "Speakers" for Creative Xmod, and then on the Levels tab. As you can see, here is where we find the playback level for Line. The problem is that SD doesn't see it since it's buried in there, so it doesn't give me a choice in Sat Radio settings to select it, in order that it can be muted/unmuted.
I believe this to be the reason behind the audio problems in Vista.
Red/Adam, please make sure Chuck sees this, although I'm sure he knows how Vista's sound engine works since he uses a Vista machine for development.
Nola111 is offline   Reply With Quote
Old 08-21-2007, 09:27 AM   #32
StreetDeckAce is an unknown quantity at this point
Will do thanks for the input. I believe he knows the how to replicate the issue it just is going to take some time to fix some other issues. We are working and will be done eventually.
StreetDeckAce is offline   Reply With Quote
Old 10-25-2007, 08:35 AM   #33
ekaz is an unknown quantity at this point
Any updates on this issue? Has anyone figured out a work around for this in the mean time?
ekaz is offline   Reply With Quote
Old 10-25-2007, 10:03 AM   #34
Nola111's Avatar
I'm wondering the same... I know they are working on an update, but I don't know if this will be addressed in the next one or not. I hope it's sooner than later, b/c this is the final issue that needs to be addressed before I can start using SD in Vista full-time. We'll see where they are when the next update comes out.
Old 12-10-2007, 03:17 PM   #35
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-11-2007, 08:14 PM   #36
Nola111's Avatar
Issue still exists in 1.1.1.0
Old 12-28-2007, 09:46 AM   #37
Aaron3262 is an unknown quantity at this point
I second that
Aaron3262 is offline   Reply With Quote
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 03:48 PM
I have a few questions regarding sound output AzzKicker Newbie 12 02-06-2004 10:49 AM
XM-PCR Sound / Digital output MeanGT General Hardware Discussion 1 12-23-2003 03:50 PM
Sound Input / Output / Interference leesilk General MP3Car Discussion 6 06-01-2003 12:47 AM
mpxplay with awe 64 very little sound output RWAudio Software & Software Development 3 06-12-2001 08:49 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
