The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Thread Tools Display Modes
Old 08-18-2007, 06:20 PM   #31
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
Here are the screenshots:
The first is XP. Everyone should recognize this. The mixer shows all channels currently available for playback. All of these channels show up as choices to pick from in Sat. Radio Settings for where my sat radio hardware is plugged into. In the first pic, the channel called "Line" is where my sat. radio is plugged in. In SD, I have line selected in Sat. Radio settings, and it mutes/unmutes correctly as I enter/exit the sat. radio module.
The second pic is Vista's playback screen. You can see that I have my soundcard "Speakers" for Creative Xmod, selected as the default. The problem is that only what you see here in this screenshot is what is available as options in Sat. radio settings in SD for what the sat radio hardware is plugged into. You can see that there is no choice there for Line. On to the third screenshot...
The third pic shows what you see if you click on Properties for "Speakers" for Creative Xmod, and then on the Levels tab. As you can see, here is where we find the playback level for Line. The problem is that SD doesn't see it since it's buried in there, so it doesn't give me a choice in Sat Radio settings to select it, in order that it can be muted/unmuted.
I believe this to be the reason behind the audio problems in Vista.
Red/Adam, please make sure Chuck sees this, although I'm sure he knows how Vista's sound engine works since he uses a Vista machine for development.
Nola111 is offline   Reply With Quote
Sponsored Links
Old 08-21-2007, 08:27 AM   #32
StreetDeckAce's CarPC Specs
Vehicle: 2000/Audi/A6
My Photos: (0)
Will do thanks for the input. I believe he knows the how to replicate the issue it just is going to take some time to fix some other issues. We are working and will be done eventually.
StreetDeckAce is offline   Reply With Quote
Old 10-25-2007, 07:35 AM   #33
ekaz's CarPC Specs
Vehicle: 2006 Dodge Charger
My Photos: (0)
Any updates on this issue? Has anyone figured out a work around for this in the mean time?
ekaz is offline   Reply With Quote
Old 10-25-2007, 09:03 AM   #34
Nola111's Avatar
My Photos: (1)
I'm wondering the same... I know they are working on an update, but I don't know if this will be addressed in the next one or not. I hope it's sooner than later, b/c this is the final issue that needs to be addressed before I can start using SD in Vista full-time. We'll see where they are when the next update comes out.
Old 12-10-2007, 02:17 PM   #35
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 12-11-2007, 07:14 PM   #36
Nola111's Avatar
My Photos: (1)
Issue still exists in 1.1.1.0
Old 12-28-2007, 08:46 AM   #37
Aaron3262's CarPC Specs
Vehicle: 1999 Toyota 4Runner Ltd
My Photos: (0)
I second that
Aaron3262 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Is all coax/optical spdif output created equal? Choser General Hardware Discussion 26 12-19-2004 02:48 PM
I have a few questions regarding sound output AzzKicker Newbie 12 02-06-2004 09:49 AM
XM-PCR Sound / Digital output MeanGT General Hardware Discussion 1 12-23-2003 02:50 PM
Sound Input / Output / Interference leesilk General MP3Car Discussion 6 05-31-2003 11:47 PM
mpxplay with awe 64 very little sound output RWAudio Software & Software Development 3 06-12-2001 07:49 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
