Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 07-08-2007, 04:44 AM   #1
Kalt's Avatar
Audio input sound Card not available in Xm settings - 1.0.9.8
What version of StreetDeck is this bug report for?
1.0.9.8
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Please list the steps required to recreate the issue you are reporting.
Please provide any relevent information regarding the issue you have encountered.
My mobo has a Realtek hd soundcard and im unable to select the correct sound card & audio line input in xm radio settings, but i can view and select them in the bluetooth mic settings. SD also fails to mute my mic after a voice command
Old install
I'm a PC
Kalt is offline
Old 07-10-2007, 08:18 PM   #2
Kalt's Avatar
Issue resolved. SD is functioning as designed.
Old install
I'm a PC
Kalt is offline
Closed Thread
No XM Sound after 1.08 update... Please Help! fiveslo StreetDeck 4 05-24-2007 01:32 AM
On-Board audio vs. Add in sound card (USB or PCI) JpLelko Newbie 8 11-04-2006 01:13 AM
Two Sound Devices; 1 for output, 1 for input XxAndyxX General Hardware Discussion 2 07-29-2006 06:56 PM
On-board Audio VS. Sound Card cadence117 Car Audio 54 01-17-2005 12:21 PM
setting sound card volume cheesyhoward Software & Software Development 8 10-17-2003 04:11 PM
