12-07-2007, 03:47 PM
#16
Good deal, thanks.
12-10-2007, 05:54 PM
#18
tested with new version 1.1.0.9, and DVD playback in Vista still does not work. Playback works fine in WMP, Media Center, and PowerDVD. I get the following error in the log:
WARNING: CDVDManager::InitDVD_Help - m_pIDvdGB->RenderDvdVideoVolume Failed - hr=0x00000001
WARNING: .\DVDManager.cpp:646 HRCALL Failed!
0x80004005 = hr = InitDVD_Help(lpszDVDPath)
INFO: Message Box:
DVD Error
There was an error while trying to initialize the DVD Video disc. Please see the log for details.
12-10-2007, 06:51 PM
#19
This is kind of ridiculous. It's obvious that this issue hasn't been given any attention at all. It doesn't appear in any of Chuck's changelogs.
12-10-2007, 07:36 PM
#20
_
As has been discussed before in detail...the reason I ask that you retest is becuse sometimes other areas of the code are affected without it being intentional.
This has happened numerous times as indicated by the numerous bug reports for instance.
We need to know if anything has changed, for better or for worse with the new update.
Also, I'm sure you've noticed that many times there are releases that we never see that only Chuck sees. Sometimes, the fixes in those versions don't find their way on the change log that he posts for one reason or another.
From my time spent as a QA specialist for a CRM development company, I've learned that testing all existing bugs when there is a release is vitally important to helping the developers save their time and efforts and focus them elsewhere.
12-10-2007, 10:22 PM
#21
Actually, my post was not directed at you at all... it was directed at the SD developer(s). I understand why you ask us to test even if the issue is not explicitly mentioned in the changelog.
Let me clarify the post I made:
It is absolutely ridiculous that the developer(s) of SD have not only made no attempt to make DVD's play in Vista, but with the several times it is mentioned in several posts, you won't ever find a post where they acknowledge that it's a problem and/or that they're looking into it.
12-11-2007, 09:26 AM
#22
_
Have you tried emailing them via the SD web site or via this site from their user profile?
It might net you some results.
Thanks for clarifying your post btw.
12-11-2007, 10:45 AM
#23
No I haven't. I would be glad to do that. Thanks.
12-11-2007, 11:48 AM
#24
Raw Wave
DVDs work on Vista in StreetDeck. It is highly dependant on your video card though. You must have a video card capable of supporting the VMR for DVDs which is the old way of doing it in XP. This works on one of the vista test machines here, but does not on the other. Vista now supports playing DVDs through the EVR which is incompatible with the VMR. Unfortunatly, because of a bug in the visual studio compiler we use, we can not add support for the EVR until a patch is made or we do a major work around.
12-11-2007, 11:49 AM
#25
BTW.... My DVD in XP doesnt work with the new update either...
'Burb-puter - worklog
12-11-2007, 03:51 PM
#26
OK.. hey that's all I was looking for! Some sort of response or acknowledgement that there IS an issue!
Thanks Chuck.
12-11-2007, 03:55 PM
#27
Thanks Chuck.
Think he mentioned it in my post about DVD on XP last week or the week before. (not that it makes it any better)
12-11-2007, 06:48 PM
#28
I'm specifically talking about Vista.
12-11-2007, 06:57 PM
#29
I know.... I was just stating he had explained the Vista problem when he summed up my issue.
12-13-2007, 09:29 AM
#30
my dvd playback did not work in XP, until I ended up uninstalling WMP11, and downgrading to WMP10.
for whatever reason, that turned out to work for me. Probably doesn't help though.
I'm running VIA EX15000G, onboard video, onboard sound.
___________________________
Velocity Red Mica Mazdaspeed 6
| Thread Tools |
| Display Modes |
Linear Mode
