Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 12-13-2007, 10:15 AM   #31
mangus580 is an unknown quantity at this point
Quote: Originally Posted by Mazdaspeed View Post
my dvd playback did not work in XP, until I ended up uninstalling WMP11, and downgrading to WMP10.
for whatever reason, that turned out to work for me. Probably doesn't help though.
I'm running VIA EX15000G, onboard video, onboard sound.
Didnt work in WMP 10 for me either.
'Burb-puter - worklog
mangus580 is offline   Reply With Quote
Old 12-14-2007, 10:26 AM   #32
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Please retest with the latest release (1.1.1.0) and report back with your findings.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-14-2007, 04:34 PM   #33
tek818 is an unknown quantity at this point
tested with 1.1.1.0 and it does not work...
tek818 is offline   Reply With Quote
Old 12-28-2007, 09:45 AM   #34
Aaron3262 is an unknown quantity at this point
Update...DVD still doesn't work and Nav fails to initialize as well... revervted back to 1.1.0.0.....Nav works again....DVD does not
Aaron3262 is offline   Reply With Quote
Old 01-30-2008, 03:22 PM   #35
bump for DVD functionality in Vista...
Old 02-09-2008, 04:04 AM   #36
djtrick9 is an unknown quantity at this point
having similar dvd initialization problem in XP
I am having the same problem in XP pro. all requisits are installed but still fail on dvdrender
i have posted a verbose log
please advise. working with trial version currently
djtrick9 is offline   Reply With Quote
Old 02-24-2008, 07:29 PM   #37
bump... what is the status of this bug?
Old 03-06-2008, 07:26 PM   #38
bump again. Next bump will be to the BBB
Old 03-27-2008, 01:06 PM   #39
FUKC streetdeck
Old 03-27-2008, 03:46 PM   #40
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
FUKC streetdeck
But the following was posted way back in December...
Quote: Originally Posted by god_of_cpu View Post
DVDs work on Vista in StreetDeck. It is highly dependant on your video card though. You must have a video card capable of supporting the VMR for DVDs which is the old way of doing it in XP. This works on one of the vista test machines here, but does not on the other. Vista now supports playing DVDs through the EVR which is incompatible with the VMR. Unfortunatly, because of a bug in the visual studio compiler we use, we can not add support for the EVR until a patch is made or we do a major work around.
Not that you don't have a point...one would expect a reply or two to a bug reports thread that's been bumped four times over the past three months...but also you never posted regarding whether or not your video card was capable of supporting VMR in Vista. So, I don't know why you expect resolution on this when the answer (even if it's not the most satisfactory answer) was posted before you ever posted.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 04-03-2008, 03:39 PM   #41
branpr's Avatar
branpr is an unknown quantity at this point
Can't play here either on Vista or WMP. going to try installing a DVD codec such as WinDVD and see if that helps. MediaCenter will play them though which has me perplexed. I had so many bugs with this garbage i could rip my face off.
AND SD Support sucks bid time. They are getting plenty of $ from people, why don't they hire a call center? They're just going to loose customers by putting out crappy code. I would buy Centrafuse in a second if they had VEarth maps. Anyone working on a mod for this? please let me know so i can plan my escape.
branpr is offline   Reply With Quote
Old 04-03-2008, 04:06 PM   #42
branpr's Avatar
I posted too soon. I Just checked the forum on Fluxmedia.com and Cenrafuse already has a Virtual Earth plugin under development. This could be a beautiful thing. Considering it has built in phone support for all bluetooth stacks and works with most phones.
Got a little off topic. but i was excited and had to share.
Old 04-07-2008, 03:27 PM   #43
branpr's Avatar
Bump Bump. any updates to this bug check? I am still not able to play DVD in SD on vista ultimate.
HOWEVER! I installed the DirectX Nov2007 package from Microsoft.com and now i can get the dvd to start and gives me either the warning or the menu. sometimes just a blank window opens up on top of the SD window and I can't see the menu so i have to close SD.
This was at least some progress anyway.
What's up with Vista? Artificial StreetDeck 15 11-29-2007 11:19 AM
Mp3 Dvd stinkyfax Newbie 2 09-23-2007 08:12 AM
House dvd player in the car & Innotek ebay screen? hmm thesupe87 General MP3Car Discussion 8 09-07-2005 12:30 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
