The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Thread Tools Search this Thread Display Modes
Old 07-31-2007, 11:42 AM   #46
Vehicle: 2006/infiniti/G35 coupe
My Photos: (0)
I just figured out how to open and edit the registration.zip file. However I do not have any idea how to change this, to make it work. I wouldn't even know where to start.
robertoftlg is offline
Sponsored Links
Old 07-31-2007, 12:17 PM   #47
My Photos: (0)
Ok, I found and changed the file locations to the mappoint folder. and I also looked to see if I had the file in the maps folder and it was there too. I ran SD and it still is doing the same thing. I try rebooting my comp but no change, so I ran you APP again and here is what it says now...
Found Mappoint ActiveX control at C:\Program Files\Microsoft Mappoint\MappointControl.ocx!
WARNING: StreetDeck Navigation Class ID NOT Found in HKEY_CLASSES_ROOT Registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
WARNING: StreetDeck Navigation Class ID NOT Found in HKEY_LOCAL_MACHINE Registry! (7F6EC72D-38AC-47A1-A9CF-4F7E832ABA10)
Mappoint Class ID Found in HKEY_CLASSES_ROOT registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
Mappoint Class ID Found in HKEY_LOCAL_MACHINE Registry! (8F78D7FC-BAE4-46A4-A79A-052356AB3DD4)
CoGetClassObject of OLE control ({8F78D7FC-BAE4-46A4-A79A-052356AB3DD4}) failed. Result code: 0x80040111
CoCreateInstance of OLE control ({8F78D7FC-BAE4-46A4-A79A-052356AB3DD4}) failed. Result code: 0x80040111
WARNING: StreetDeck navigation control creation failed!
WARNING: Failed to create streetdeck navigation object window, trying to create mappoint navigation window!
WARNING: Mappoint navigation control creation failed!
FATAL ERROR: Failed to create mappoint navigation object window!
Old 07-31-2007, 12:35 PM   #48
StreetDeckAce's CarPC Specs
Vehicle: 2000/Audi/A6
My Photos: (0)
I will report this to chuck.
StreetDeckAce is offline
Old 08-04-2007, 07:35 PM   #49
My Photos: (0)
OK, I have tried every conceivable install order and found one method that kinda works. I first un-installed SD, Mappoint, and deleted all registry entries I could find under Mappoint and Streetdeck. I then ran the setup.exe from the SD install files on my hard drive. Then I went online and downloaded the 1.1.0.0 update, and installed it. I then ran the registry.zip. With this, I can now run the mappoint test app without it crashing, and it now works. I can see the map in the corner and I have no warning messages. When I open SD the navigation button is there! But when I click on it, it say initializing navigation for about 2 minutes, then closes SD, and pops up two error messages saying that SD needed to close and I should call your support phone number during business hours. So I ran a search for the SD APP log, but I can't find any new log files to see what the problem is. Please let me know what I should do next.
Old 08-04-2007, 08:05 PM   #50
My Photos: (0)
found the latest log file...
Hey, I found the log file and attached it. Also, I opened mappoint manually and checked the com addins and found the streetdeck addin was unchecked, I checked the box and closed the window. but when I reopened it, it was unchecked again, and it has no load behavior. The reason I bring this up is, In a previous install the box was checked and it had a load behavior something like "load at startup". I hope this helps.
Sponsored Links
Old 08-06-2007, 05:01 PM   #51
Raw Wave
god_of_cpu's Avatar
Vehicle: 2003/Infiniti/G35 Sport Coupe
My Photos: (0)
What happens when you run
regsvr32.exe "C:\Program Files\StreetDeck\MappointAddin.dll"
Also try downloading depends (http://www.dependencywalker.com/) and running it on MappointAddin.dll and post if you are missing any dependancies.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 08-06-2007, 08:35 PM   #52
My Photos: (0)
I ran dependencywalker and here is what it says...
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
these files were highlighted...
SHLWAPI.DLL
IEFRAME.DLL
I tried attach the file but I guess it is not an approved file extension, because it would not upload ".dwi"
Old 08-06-2007, 09:51 PM   #53
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
I'll go in and add that file type real quick to the allowed types. One moment.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 08-06-2007, 09:54 PM   #54
_
My Photos: (90)
done...though no icon for it...
Jan Bennett
Old 08-07-2007, 11:09 AM   #55
My Photos: (0)
Our engineer should have a solution for this issue soon. I have overnighted him a PC with the issue on it. I will keep you updated on his progress.
Old 08-07-2007, 04:03 PM   #56
My Photos: (0)
Dependency walker file...
Here is a copy of the dependency walker file for mappoint addin.dll
Thanks for adding the extension.
Old 08-08-2007, 12:14 PM   #57
My Photos: (0)
Thank you I will forward this to our engineers. To help in the process
Old 08-09-2007, 08:22 PM   #58
Fama's CarPC Specs
Fama's Avatar
Vehicle: 2002/ BMW/ 530d M-Sport
My Photos: (1)
Hey jus another newbie in the block!
I have tried everything but still get the UNBOUND #4. Is there any simple solution before i go boncus!
Fama is offline
Old 08-10-2007, 12:47 PM   #59
My Photos: (0)
A solution is near!
Old 08-16-2007, 08:14 AM   #60
_
My Photos: (90)
To all of you who have purchased the European version of StreetDeck and have recieved your DVDs, please check your emails. You should have recieved an email from a representative of the company. Please post back here once you have followed through with the email.
If you purchased the DVD but have not recieved an email, please let me know.
Jan Bennett
Sponsored Links
Closed Thread
Search this Thread:
Advanced Search
Trackbacks are Off
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 09:15 PM
Power Button not working? NoTicketsPlease Newbie 5 02-28-2006 10:43 PM
Lots of Cool RR functionality, can we enhance button event model? ruairi Road Runner 2 04-04-2005 03:45 PM
PC power button problem BMp3W Power Supplies 4 10-12-2002 02:36 AM
internet button on my pc babas151 General Hardware Discussion 10 05-31-2002 02:41 PM
Sponsored Links
Ad Management by RedTyger
