Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 08-21-2007, 11:15 AM   #16
StreetDeckAce is an unknown quantity at this point
Got the same results. We are working on a solution. This requires that we rewrite the whole sound control scheme for streetdeck. There is no ETA on the solution.
StreetDeckAce is offline   Reply With Quote
Old 08-23-2007, 09:18 PM   #17
jayearl is on a distinguished road
XP compatibility mode in Vista works for me
Wow.
I was trying everything to get the volume to work and running SD under XP SP2 compatibility finally made the volume work.
Fixed my problem!
jayearl is offline   Reply With Quote
Old 08-23-2007, 09:26 PM   #18
Fixed volume, broke Navi.
Got way too excited.
Volume works, but Navigation is now broke when trying to run SD in XP SP2 compatibility. Back to square one.
Old 08-26-2007, 06:21 PM   #19
Nola111's Avatar
Nola111 is an unknown quantity at this point
There are several issues I encountered with SD in Vista while trying to run under XP compatibility mode. It may fix the volume issue, but it "breaks" several other functions (incl. Nav, XM, and some button finctionalities). I would not recommend running Streetdeck in XP compatibility mode for any reason.
Nola111 is offline   Reply With Quote
Old 12-10-2007, 03:14 PM   #20
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-14-2007, 10:18 AM   #21
_
Please retest with the latest release (1.1.1.0) and report back with your findings.
Jan Bennett
Old 12-19-2007, 09:18 AM   #22
Aaron3262 is an unknown quantity at this point
I will test this tonight, and report back, Thanx for all your help Red
Aaron3262 is offline   Reply With Quote
Old 12-20-2007, 09:04 AM   #23
Well I installed the latest update and when I started SD, it said I was running the Demo copy and asked for the reg info. I found it, entered it in, and got SD up and running again. The Nav module won't initialize now saying the map data isn't installed. However all of the bugs I reported including this one still don't work so I think something happened with the upgrade. I need to get the Nav working again so I'll probably uninstall and start fresh. I'll report back once I get everything going again.
Old 12-21-2007, 05:03 PM   #24
tek818 is an unknown quantity at this point
verified.... volume control does NOT work in 1.1.1.0 on Vista
tek818 is offline   Reply With Quote
Old 12-28-2007, 09:48 AM   #25
I reverted back to 1.1.0.0 to get the Nav module to initialize, but the volume control doesn't work in any version on Vista
Old 02-12-2008, 01:32 AM   #26
bump for some vista love
Feature request: A separate volume control for each plugin Lum Centrafuse 4 07-31-2006 03:56 PM
Multiple Soundcards - Volume Control... Jarrod Road Runner 23 07-17-2006 01:25 PM
Change behaviour Volume control DbXL Centrafuse 0 07-09-2006 12:09 PM
volume control JaxPt Software & Software Development 3 04-21-2005 07:44 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 11:43 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
