Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 07-14-2007, 01:53 PM   #1
Aaron3262 is an unknown quantity at this point
Severity 2 Volume Control Doesn't Work in Vista - 1.0.9.8 - 1.1.0.0
What version of StreetDeck is this bug report for?
1.0.9.8 - 1.1.0.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Move the volume slider up or down to mute and the volume doesn't change. However when I move the slider for the playing media the volume changes. The only way to change the volume is with the Vista volume control in the taskbar.
Please provide any relevent information regarding the issue you have encountered.
I originally tested SD on a XP machine earlier this year and it worked so I don't know if it is Vista or my new machine.
Aaron3262 is offline   Reply With Quote
Advertisement Sponsored links
Old 07-15-2007, 03:05 PM   #2
Discoputer is an unknown quantity at this point
me too same problem
Discoputer is offline   Reply With Quote
Old 07-17-2007, 06:08 PM   #3
1.1.0.0- Volume
Volume still doesn't work in Vista in version 1.1.0.0
Old 07-17-2007, 08:00 PM   #4
I get the same results with the volume with 1.1.0.0
Old 07-18-2007, 02:29 PM   #5
StreetDeckAce is an unknown quantity at this point
We are aware of this issue with vista and Streetdeck. There is a cheep solution with a griffin powermate for volume control. Other than that we are working on a software solution but this is a lower priority issue due to the low number of vista car PC's. I will report the issue to our developers again. Thank you for the testing and reports!
StreetDeckAce is offline   Reply With Quote
Old 07-18-2007, 05:14 PM   #6
lol, that thing will look great on my dash, Thanx but I think I will wait and see if it can be done in software wth an update
Old 07-25-2007, 12:25 AM   #7
I have an idea of a temporary workaround. How hard would it be to code a check box in settings that when checked will allow the main volume slider to be directly tied to the playing media slider, because the playing media slider works in Vista. Thanx in advance
Old 08-10-2007, 12:02 PM   #8
changeip is an unknown quantity at this point
Your kidding right?
I used the demo and got some choices of which line to output sound on ... the volume didn't work, but I assumed it was configurable down the road so I didn't mess with it. Now that I purchased SD I find I can't control my volume ? I can't even figure out how to reconfigure the sound output anymore, it's no longer an option. 1.1.0.0
I'd like a refund if that's the case - no point in spending $200 for something I can't even use the volume control in. Isn't volume on of the most important parts of this whole program? I can't reach half way across my cab everytime i want to turn the volume up and down - in a full size truck that's just dangerous. I can't believe this isn't the highest priority at the moment. Rediculous.
Sam
changeip is offline   Reply With Quote
Old 08-10-2007, 12:28 PM   #9
Kalt is on a distinguished road
SD has never had a config for which line to output sound so you must be talking about the xm configuration. SD is also optimized for xp not vista, and when you bought the software windows xp home/pro is listed as the required OS.
Kalt is offline   Reply With Quote
Old 08-10-2007, 12:35 PM   #10
http://www.mp3car.com/vbulletin/stre...oad-links.html
Per the above I show Vista as a supported OS ? Was I mislead ? I wouldn't have bought it if I knew vista wasn't supported.
Old 08-10-2007, 03:13 PM   #11
I have spent some time working with vista and SD. Some sound cards like to play nice and some do not. I have reported this to our engineers and they are currently working on a solution that should fix this. Until then I understand the importance of volume control. I'm a control freak. I just added THIS to the store. For $25 it works great with SD. I will report back as soon as I hear more on vista control.
Old 08-13-2007, 11:34 AM   #12
Yea I think the on board sound on my AOpen by realtek is one of the sound cards that didn't agree with Vista. I installed the latest Realtek driver and software to get the line-in passthourgh to work.
Old 08-19-2007, 01:39 PM   #13
marchello2000 is on a distinguished road
I assume that the problem is Vista volume control virtualization which SD needs to work around (such as described here, for example, http://blogs.msdn.com/larryosterman/...ows-vista.aspx)
However, there is a quick solution that should work (read - I haven't tried it, but think it will work): right click on the SD shortcut and click on the compatibility tab, make SD run in XP SP2 compatibility mode which turns off various (including volume) virtualization.
Mark
marchello2000 is offline   Reply With Quote
Old 08-20-2007, 12:03 PM   #14
I will test this on other machines. Thanks for the input.
Old 08-20-2007, 09:23 PM   #15
Nola111's Avatar
Nola111 is an unknown quantity at this point
Mark
Mark, I tried running SD in XP Compatibility mode per your suggestion, and it did not fix any issues for me, and in fact, it made things worse for running XM. Running in this mode caused me to have no soundcard choices at all in my Sat. Radio settings. I tried entering the Sat Radio module anyway, and I got stuck in an error message loop that locked me from doing anything other than hitting ok on the error message (message was "Incompatible sound device for Sat. Radio" or something of this nature). I had to force a shutdown of my pc to get out of the loop.
So anyway, if anyone tries SD in XP Compatibilty mode, MAKE SURE to check your Sat. Radio settings... if there are no sound card choices at all, DON'T try to open the Sat. Radio module, or you'll be forced to reboot. If you don't use Sat. Radio in SD, then this may be a satisfactory workaround for volume control.
I hope this bug is addressed soon.
Nola111 is offline   Reply With Quote
Feature request: A separate volume control for each plugin Lum Centrafuse 4 07-31-2006 03:56 PM
Multiple Soundcards - Volume Control... Jarrod Road Runner 23 07-17-2006 01:25 PM
Change behaviour Volume control DbXL Centrafuse 0 07-09-2006 12:09 PM
volume control JaxPt Software & Software Development 3 04-21-2005 07:44 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 11:43 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
