Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 07-19-2007, 05:31 PM   #1
TheSin's Avatar
Severity 4 - Lowest Font Import - 1.1.0.0
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Font Import
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
here is the error
WARNING: CFontUtil::Convert - Conversion Failed! The height of the input bitmap (C:\Documents and Settings\TheSin\My Documents\StreetDeck\UI\Skins\Ford\Fonts\Font25.pn g) is not evenly divisible by the number of supported characters (95)
And I copied them right from the Default theme, any ideas?
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
open a new theme, click import font, select the font, I have tried them all.
Please provide any relevent information regarding the issue you have encountered.
TheSin is offline
Advertisement Sponsored links
Old 07-20-2007, 10:18 AM   #2
Raw Wave
god_of_cpu's Avatar
The font import tool is for importing font templates. The import tool will take a template and output a font that can be used with StreetDeck. The fonts distributed with StreetDeck are the output of the font import tool and are NOT templates.
Please see this thread for additional details on creating fonts. The font templates used to create teh default fonts are also linked in this thread. to create a new font, you should modify the font template, then send it through the import tool which will result in the new font.
http://www.mp3car.com/vbulletin/digi...eck-fonts.html
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 07-20-2007, 01:11 PM   #3
TheSin's Avatar
ahh I understand now thanks, sorry about the bogus report. I think I have the hang of this skinning stuff now, I hope Spent the last 12hours working on one and only have one small bug thus far that I can see.
As a side note, is it bad form to make a skin that expects certain digital mods to be installed? Like is that frowned on?
TheSin is offline
Old 07-21-2007, 11:00 AM   #4
_
Issue resolved, thread closed.
I'd ask your question directly to chuck via email or I'd post it in the general discussion are of StreetDeck. We need to keep bug reports clean if at all possible.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Closed Thread
Lsx Void 3.0 liquid_smoke RR Skins 2885 Yesterday 06:01 AM
Need a font... GE Drover? RoyN Off Topic 10 11-24-2006 08:43 PM
MM font problem continues grnikolis Map Monkey 13 07-16-2006 05:31 AM
Font Type not been used in Phoco Skin RS200Z RR Bug Tracker 1 04-21-2006 09:17 AM
StreetDeck Fonts god_of_cpu DigitalMods (Scripts / API) 1 02-16-2006 05:21 PM
