The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Thread Tools Display Modes
Old 07-23-2007, 03:35 PM   #1
strohj's CarPC Specs
strohj's Avatar
Vehicle: 2004 VW R32 ... 2006 Jeep Commander
My Photos: (0)
Severity 2 XM Ignore list clears out after restart of streetdeck - 1.1.0.0
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Please provide any relevent information regarding the issue you have encountered.
I can go into XM radio and ignore stations and as long as streetdeck stays open.. even through a hibernate or a standby.. the ignore list is fine.. however i I close streetdeck.. or restart my pc(which closes streetdeck)... the ignore list gets lost.
strohj is offline   Reply With Quote
Sponsored Links
Old 08-02-2007, 08:37 AM   #2
strohj's Avatar
My Photos: (0)
I forgot to add.. I am using a XM-direct with a serial cable.. and I have XM-direct compatibility checked in the settings...
I think it might have something to o with the order in which it does things.. it might check the ignore list too soon.. as in before it has finished updating the channel list from the XM-direct...
Old 08-16-2007, 09:54 AM   #3
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
I've just tested this on my laptop with the USB Xm Adapter avaliable here on the store and I cannot recreate it.
I have SD set to close the program when I tell it to turn off. I even close the tray application before restarting SD. I will see if I can recreate it by completely restarting the laptop, not just SD.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 08-16-2007, 09:57 AM   #4
strohj's Avatar
My Photos: (0)
I wonder if it has something to do with the serial cable vs the USB interface then?...
Old 08-16-2007, 10:05 AM   #5
_
My Photos: (73)
Ok - I've just restarted my laptop and station 1 is still ignored on my system.
Now I have one more test to try. I'm going to remove power to the USB box to see if it's storing settings (I'm testing this on my test bench with my laptop...in the car I'd like to hook to ignition instead of constant).
Jan Bennett
Old 08-16-2007, 10:08 AM   #6
strohj's Avatar
My Photos: (0)
my XM is powered off the ignition power... and I have a lot more than just 1 channel ignored... I did notice that every now and then when I go back in to ignore channels.. it would have remembered a random channel here and there that was on my previous ignore list ..
so this might be something more of a bug with a big ignore list?
Old 08-16-2007, 10:08 AM   #7
_
My Photos: (73)
Ok - removed power to the USB adapter and station 1 is still ignored.
Seems to be either a machine/user specific issue or that the serial cable doesn't handle this feature like it should.
We need to get someone else who has the same cable to test and confirm their results.
EDIT: I've also just unplugged USB and power to the device and the stations stay ignored.
Jan Bennett
Old 08-16-2007, 01:21 PM   #8
dnatrance's CarPC Specs
My Photos: (0)
I am having the same exact problem with mine also. They channels sometimes default back and none are ignored, but most of the time it is just a channel or two that gets unignored.
dnatrance is offline   Reply With Quote
Old 08-16-2007, 03:24 PM   #9
strohj's Avatar
My Photos: (0)
are you using the serial cable or the USB one?
Old 08-16-2007, 04:18 PM   #10
My Photos: (0)
I am using the mp3car usb
Sponsored Links
Old 08-16-2007, 04:20 PM   #11
strohj's Avatar
My Photos: (0)
do you have a lot of channels ignored? I have propably around 20-25 ignored
Old 08-16-2007, 05:04 PM   #12
_
My Photos: (73)
I've ignored 44 stations. I've made a list of all of the stations, I then went back and marked off the one's I had checked to ignore. I rebooted, etc then went back and checked all 246 channels and compared the ignored ones with the ones on my list. It all lines up like expected.
Jan Bennett
Old 08-16-2007, 05:55 PM   #13
strohj's Avatar
My Photos: (0)
I can reproduce this every time now... I ignored channeld that XM are not broadcasting.. for example channels 18 and 19 among others ...
when I ignore those.. my ignore list gets messed up and doesnt get saved when I exit streetdeck... if I only ignore valid XM channels... the ignore list function works perfectly as expected
so I guess the bug needs to changed.. but I have a workaround for now
Old 08-17-2007, 01:18 AM   #14
My Photos: (0)
I will do some more investigation tomorrow. As far as shutting down, hibernate, cutting the power ect ect.
Will let you know what I get.
also, I will try it with a few channels and a bunch.
Old 12-10-2007, 02:14 PM   #15
_
My Photos: (73)
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
Occasional Song List Hickup with XM chuckster Road Runner 5 11-25-2005 12:09 PM
XM channel list screwing up... Snootch Road Runner 1 11-10-2005 08:37 AM
XM screen shows mp3 list wysocki RR Bug Tracker 2 08-17-2005 09:24 PM
XM Player, Channel List scrunched?? KingsDude FrodoPlayer 2 05-13-2005 01:04 AM
List the software you use for XM kickercivic1 Software & Software Development 0 12-18-2004 09:21 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
