Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 07-28-2007, 12:26 AM   #1
Sinabl is an unknown quantity at this point
Severity 4 - Lowest Bluetooth GPS connection issue - 1.1.0.0
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
When you hibernate and then start the computer back up, SD will automatically pair with the bluetooth GPS.
However, if you do a standby and come out of standby, it wont pair with the bluetooth GPS.
Please provide any relevent information regarding the issue you have encountered.
Sinabl is offline   Reply With Quote
Advertisement Sponsored links
Old 07-28-2007, 05:33 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Please test this outside of StreetDeck. We need to determine if this is really a StreetDeck bug or if this is an issue with that particular GPS reciever.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 08-01-2007, 10:50 PM   #3
ok i tested it out.
If i hibernate and then return back to windows, my GPS will not automatically pair with my laptop unless i tell blue-soleil to do so (as expected).
If i hibernate and then return back to SD from hibernation, SD will automatically pair my laptop with the GPS (as expected; SD is a savior and auto-connects).
If i standby and then return back to windows, my GPS will not automatically pair with my laptop unless i tell blue-soleil to do so. (as expected)
If i standby and then return back to SD, SD will NOT pair my laptop with the GPS. (unexpected; SD should auto-connect similar with hibernation)
Old 08-08-2007, 06:15 PM   #4
Any updates?
Old 12-10-2007, 03:12 PM   #5
_
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
Old 12-14-2007, 10:36 AM   #6
_
Please test with the latest release (1.1.1.0) and report back with your findings.
Jan Bennett
Bluetooth COM port interfering with GPS COM port fatejd GPS 7 04-03-2007 02:47 PM
Bluetooth phone and GPS dpetteng Centrafuse 2 11-03-2006 07:02 AM
My GPS scenario & Bluetooth quest. gizak GPS 13 04-12-2005 01:11 PM
Earthmate GPS Reciever Com Port issue in Map Monkey aseraj Map Monkey 3 03-31-2005 07:17 AM
Mobile/PDA use gps on laptop via bluetooth chenko GPS 0 01-14-2005 09:08 PM
