Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 07-28-2007, 02:10 AM   #1
BlueF is on a distinguished road
Severity 3 Phidget Encoder Plug-in Doesn't Stay Enabled - 1.0.6.3+
What version of StreetDeck is this bug report for?
1.0.6.3+
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
1) Phidget Encoder Input Plugin Enabled and Functioning normally.
2) Disconnect Phidget
3) Power on PC (and StreetDeck) with Phidget disconnected (i.e. PC removed from car for maintenance/updates/etc... phidget "hard-wired" (integrated) into car).
4) Return PC to car, re-attach phidget, power on PC and SD.
BUG: Phidget Encoder no longer enabled. Must be manually re-enabled.
Not sure if this is by design or if the setting/device can be remembered even if it is temporarily disconnected (SD operated with the phidget physically disconnected).... that would be very nice to have!!
Thank you,
Blue
Please provide any relevent information regarding the issue you have encountered.
2008 Subaru Impreza WRX-STI
Pioneer AVIC-D3 <-- poooor comparison to StreetDeck!!!
Would be building another car PC, if I thought StreetDeck wasn't on the verge of dying off. : (
(Dec 07)Sold 04 WRX, In-Dash Touchscreen, MacMini, running StreetDeck.
BlueF is offline
Advertisement Sponsored links
Old 07-30-2007, 11:12 AM   #2
StreetDeckAce is an unknown quantity at this point
This is not hardware currently supported by SD. Where did you get the Encoder? we can test if you are more specific on the type of hardware you are using.
StreetDeckAce is offline
Old 08-06-2007, 10:41 PM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
because this isn't hardware that's supported by StreetDeck, this thread has been closed.
Jan Bennett
RedGTiVR6 is offline
Closed Thread
MMI style rotary encoder install - details Tony G Input Devices 59 06-01-2008 02:41 PM
Possible Bugs: Phidget Encoder Doesn't Stay Enabled and Music Import Duplication BlueF StreetDeck 0 07-20-2007 12:36 PM
Phidget Encoder and RR Volume Control BLOWNZO6_pc Road Runner 28 10-25-2005 11:00 AM
IRman repeat delay wont stay enabled... Cadillac_LoungN ME Archive 0 04-18-2003 03:50 AM
