Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 07-31-2007, 02:37 AM   #1
Indy is an unknown quantity at this point
Severity 2 -DisableWindowHooks not working - 1.1.0.0
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
if SD started with -DisableWindowHooks key - it still prevent other programs to start over SD. if press "settings-toggle fullscreen" button, and press it again - then alt-tab working properly, and working before next SD restart.
Please provide any relevent information regarding the issue you have encountered.
Indy is offline
Advertisement Sponsored links
Old 07-31-2007, 09:15 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
I am able to recreate this issue. I will report it to Chuck to find out if this is functioning as designed.
Jan Bennett
RedGTiVR6 is offline
Old 07-31-2007, 09:24 AM   #3
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
The window hooks only prevent certain windows from being shown like license and some login dialogs. The command line parameter is in there for debugging purposes only and doesn't really have much practical use.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 07-31-2007, 09:40 AM   #4
_
thanks for the info Chuck. Thread closed. Functioning as designed.
Jan Bennett
Closed Thread
Crossfading does not work. - 1.0.8.1 - 1.1.0.0 S4Per StreetDeck Bug Reports 22 01-31-2008 04:12 PM
only odd or only even FM stations - 1.1.0.0 Indy StreetDeck Bug Reports 3 08-07-2007 02:24 PM
SPV M700 / HTC P3600 not working with Phonecontrol Tracert PhoneControl 0 07-13-2007 11:16 PM
Anyone currently working with 18f2550 lez General Hardware Discussion 17 11-03-2006 08:44 AM
motorized screen stopped working :( corsamel LCD/Display 0 11-26-2002 11:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
