Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 07-31-2007, 01:58 AM   #1
Severity 4 - Lowest only odd or only even FM stations - 1.1.0.0
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
if SD started without -RadioTuneEvenStations - only odd FM stations are working. If started with -RadioTuneEvenStations - _only_ even stations are working, not both odd&even. I'm from Russia, here used both even and odd FM stations.
Please provide any relevent information regarding the issue you have encountered.
Indy is offline
Advertisement Sponsored links
Old 08-06-2007, 07:45 PM   #2
pim
tuner autoscan hardcoded to odd frequencies
1.1.0.0
Using the command line parameter "-RadioTuneEvenStations", the tune and scan buttons will advance to even frequencies on the builtin tuner in the Infill G4, which is necessary in Europe and probably elsewhere.
However, the Autoscan menu still searches odd frequencies only.
Also, IMHO "RadioTuneEvenStations" should be a configurable option in the settings menu rather than a command line option.
no
Non mp3car.com Infill G4
Demo version
pim is offline
Old 08-06-2007, 09:39 PM   #3
_
threads merged.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 08-07-2007, 01:24 PM   #4
This is operating as designed. Making this another button to confuse people in SD rather than a command line parameter would not be good. The likelihood of a car with SD going from the US to europe is not enough to make a switchable button in SD.
StreetDeckAce is offline
Closed Thread
Updated to 1.0.9.8 on T3 messed up Radio AND now 1.1.0.0 jabz StreetDeck 16 07-24-2007 12:03 PM
HD Radio FAQ RedGTiVR6 BoomzBox HD 0 07-19-2007 12:02 PM
centrafuse won't search fm stations automatically glenrijke Centrafuse 2 01-23-2006 06:52 PM
FM Radio - remove stations? And line-in mute OrangePeel ME Archive 3 11-18-2003 03:50 PM
