Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 08-06-2007, 07:35 PM   #1
pim
Severity 4 - Lowest album art aspect wrong - 1.1.0.0
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
Album art is displayed wrong on a wide screen like the Infill G4, regardless of the "Display Format" setting. Most notably in the "Now Playing" menu, but also in the mini view.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
no
If no, please describe your system here.
Non mp3car.com Infill G4
Please provide any relevent information regarding the issue you have encountered.
Demo version
pim is offline
Advertisement Sponsored links
Old 08-06-2007, 09:37 PM   #2
_
need screen shots and logs to go any further.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 08-07-2007, 03:58 PM   #3
pim
Very well,
Here's sample album art, 300x300
Here's how it looks in Streetdeck, windowed mode. Looks OK.
But the problem is in fullscreen mode. Album art is really stretched.
log file
Pim
pim is offline
Old 08-07-2007, 04:52 PM   #4
_
Thanks for the images and the log!
Jan Bennett
Old 08-21-2007, 09:26 AM   #5
This is operating as designed. SD resolution and album art corresponds to the resolution setting of the graphics card.
StreetDeckAce is offline
Old 08-21-2007, 09:38 AM   #6
pim
My point is that is not corresponding. SD is enforcing a 4x3 aspect when the screen is in fact a 16x9 resolution screen.
Pim
pim is offline
Old 08-21-2007, 10:08 AM   #7
Nola111's Avatar
I have to disagree with this based on my usage. When I'm using SD in 16:9 aspect in my car or on my widescreen laptop, nothing appears stretched like in his screenshot.
Nola111 is offline
Old 08-21-2007, 10:30 AM   #8
pim
Are you running SD fullscreen 16:9 ?
Seeing that you are not using a G4, does the 16:9 versus 4:3 setting under display settings have influence over how album art is shown?
On a G4 this setting is "stuck" to 4:3, but I was told, this should not matter.
Pim
pim is offline
Old 08-22-2007, 05:47 PM   #9
pim
I tried SD on a desktop PC with a 1600x900 widescreen display.
I see the same album art stretching as on the Infill G4. Viewing pictures using the Pictures menu also shows stretched pictures.
On this PC, I also had the opportunity to see what the effect is of the "Display Format" setting (16:9 vs 4:3). It has no effect on album art and picture viewing.
It does have an effect on playing video's. The aspect is right if you set it to 4:3 on this 1600x900 screen with 16:9 resolution and 16:9 size. Video's show too narrow if you set it to 16:9.
This is confusing. What the setting really should be called is "wide pixels" versus "square pixels". It should only be set to 16:9 on a screen with 4:3 pixel resolution and 16:9 physical dimensions.
But again this is for video's only. Pictures and album art are always stretched on a widescreen display with square pixels. This is inconsistent in the way SD handles videos.
Pim
pim is offline
Old 08-22-2007, 09:03 PM   #10
...I just ended up "stretching" the buttons vertically to compensate for the horizontal stretch that Streetdeck does when it gets put into widescreen. It looks funny in windowed 4:3...but fine in fullscreen 16:9.
Tranman is offline
Old 08-29-2007, 09:37 AM   #11
Raw Wave
god_of_cpu's Avatar
pim is correct, the 16x9 setting is only for videos, it should also only be used on widescreen displays that are used with a video card that only outputs a 4x3 resolution to stretch the video so that the pixels appear unstretched even though the display resolution is a stretched 4x3 resolution.
Other then that, StreetDeck doesn't have any other concept of widescreen displays. It will stretch everything evenly to your display resolution. THis is a known limitation.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 08-29-2007, 10:30 AM   #12
pim
Could this be solved through a custom widescreen skin?
Pim
pim is offline
Old 08-29-2007, 10:32 AM   #13
Raw Wave
god_of_cpu's Avatar
Not album art. You can solve most other aspect ratio problems with a aspect corrected skin though.
Old 08-29-2007, 11:47 AM   #14
_
Thread closed since the reported issue is not a bug.
Jan Bennett
Closed Thread
Album art downloader hijinks21 Software & Software Development 105 07-20-2006 09:56 AM
Highlighted dirs only show a few chars, album art still borked fury RR Bug Tracker 2 05-09-2006 09:42 AM
Album art browse bugs? froop RR Bug Tracker 0 12-11-2005 12:02 AM
album art in id3 causes improper read hateeecs CF Bug Reports 9 09-06-2005 12:34 PM
