Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 08-09-2007, 12:55 PM   #1
pim
pim is on a distinguished road
Severity 3 FM Tuner skips many frequencies - 1.1.0.0 - 1.1.1.0
What version of StreetDeck is this bug report for?
1.1.0.0 - 1.1.1.0
Please give a basic description of the issue here.
Tuner control buttons always advance or decrease FM frequencies in 0.2 MHz increments, thereby missing half of available radio stations. This applies to the "tune" and "scan" buttons in the tuner menu, and the "autoscan" menu under settings. Using the tuner slider is it possible to select almost, but not all frequencies.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
No
If no, please describe your system here.
Non mp3car installed Infill G4.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
Select AM/FM Radio, select FM, press the "Tune +" button. The tuner will advance 0.2 Mhz and possibly miss a station only 0.1 MHz away.
Select Show Tuner, use the slider and slide to 92.0 MHz. Slide slowly to 93.0 MHz. Every intermediate frequency is shown, in 0.1 MHz steps, except 92.8 MHz.
Please provide any relevant information regarding the issue you have encountered.
There appears to be no commandline option or setting that alters this behaviour.
pim is offline   Reply With Quote
Advertisement Sponsored links
Old 12-10-2007, 03:12 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-10-2007, 06:10 PM   #3
pim
Unfortunately, the problem has become worse.
Increments are still 0.2 MHz rather than 0.1 MHz in the scan functions.
But the previous version featured a slider at the bottom that would allow one to select almost any frequency. This slider is now replaced by one that also uses 0.2 MHz increments consistently.
The keypad allows odd frequencies to be entered only, regardless of the -RadioTuneEvenStations command line option.
Pim
Old 12-10-2007, 06:13 PM   #4
_
thanks for the update - original post and thread title updated.
Jan Bennett
Old 12-14-2007, 10:24 AM   #5
_
Please retest with the latest release (1.1.1.0) and report back with your findings.
Jan Bennett
Old 12-19-2007, 12:59 PM   #6
pim
No changes.
Pim
Old 07-24-2008, 08:32 PM   #7
JasonMK's Avatar
JasonMK is an unknown quantity at this point
Quote: Originally Posted by pim View Post
No changes.
Pim
I know this is an older post, but did SD version 1.1.1.6 fix your problem? Worked for me
_______________________________________________
All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
JasonMK is offline   Reply With Quote
HQCT software development Putput Software & Software Development 177 05-17-2009 01:19 PM
E46 Rubbish Radio Reception, whats the best fm tuner? Craggy General Hardware Discussion 0 05-18-2007 06:54 AM
XM and FM tuner pshadwick Newbie 4 03-09-2006 06:45 PM
FM Tuner Card, or remove hu? gareva1 Car Audio 12 08-16-2005 09:55 AM
ok I need a usb radio tuner ... v2.0 - the FM Mouse is crap. mattress Input Devices 2 04-10-2005 12:18 AM
