Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Old 08-13-2007, 04:12 AM   #1
Deadeye is an unknown quantity at this point
Severity 4 - Lowest Black screen when come back from hibernate
What version of StreetDeck is this bug report for?
1.1.0.0
Please give a basic description of the issue here.
When I have a script installed that uses CreateHostWindow, then when coming back from hibernate I get a black screen, and music has stopped.
During this time, the buttons (which you cant see) in streetdeck still work. When you press them they make the button press noise.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Infill G4
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting.
1) Load basic sample http://www.mp3car.com/vbulletin/stre...1-1-0-0-a.html
2) Install it on SD pc
3) Load SD
4) Turn car off (Go into hibernate)
5) Turn car on
www.ssw.com.au
Deadeye is offline   Reply With Quote
Advertisement Sponsored links
Old 08-13-2007, 08:26 AM   #2
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
Please run with -verbose and post another log.
Does it eventually come back if you wait a while? Sometimes some devices can take a while to come out of hibernation and StreetDeck will wait for them until they do.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 08-20-2007, 11:12 PM   #3
Here you go.
No doesnt come back.
buttons still work
In this log:
*load
*start playing audio file
*turn off car
*turn on car
*black screen
*press black area where buttons are to shutdown
www.ssw.com.au
Old 08-21-2007, 09:26 AM   #4
Raw Wave
god_of_cpu's Avatar
Does it work if you rename your my documents\StreetDeck\Scripts directory?
Old 08-30-2007, 02:38 AM   #5
You are correct Chuck.
By renaming the scripts directory, SD does return from hibernate correctly.
I have moved this thread to the bug form as I have been able to replicate the error with a sample plugin.
Get the sample from here
Looks like the issue affects any plugin that uses CreateHostWindow()
www.ssw.com.au
Old 08-30-2007, 10:50 AM   #6
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Please edit your first post to reflect the proper bug reporting form.
Just go to another bug report and copy the form over. We need this informatio in the first post to make tracking easier.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 12-10-2007, 03:14 PM   #7
_
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
Old 12-14-2007, 10:18 AM   #8
_
Please retest with the latest release (1.1.1.0) and report back with your findings.
Jan Bennett
Old 12-15-2007, 05:14 PM   #9
Im away over xmas so testing is not that easy.
However after a quick test it does seem to be working correctly.
YAY!
thanks.
www.ssw.com.au
Old 12-15-2007, 08:44 PM   #10
tek818 is an unknown quantity at this point
black screen when resume from hibernate on 1.1.1.0 on Vista
tek818 is offline   Reply With Quote
Old 02-12-2008, 03:14 AM   #11
This has been fixed on XP.
Not sure about vista
www.ssw.com.au
Boot to black screen RedGTiVR6 General Hardware Discussion 3 05-16-2007 06:52 PM
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
Chinese company will not send my screen back and its been 5 months !!! TheGuy General Hardware Discussion 25 04-06-2007 04:03 PM
Blue Devil Skin RELEASED JohnWPB RR Skins No Longer Supported 1005 01-05-2007 08:54 PM
How do I get back to the setup screen? kiztope Media Engine 1 03-09-2004 03:19 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
