Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 09-01-2007, 11:57 AM   #1
Severity 3 Navigation slow to resume after hibernate - 1.1.0.0
What version of StreetDeck is this bug report for?
1.0.9.8-1.1.0.0
Please give a basic description of the issue here.
Usually (with only a few exceptions) Navigation has low signal for 1-5 (or more) minutes.
Is the system that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
Reproduceable?
On my computer...
Please provide any relevant information regarding the issue you have encountered.
If I start streetdeck after a system reboot, nav shows my position immediately. After hibernating, it usually takes a while for the nav to get a signal. There is ALWAYS a delay after resuming from hibernate. Occasionally, the GPS starts after 30 seconds. A few times, it has literally taken more than 5 minutes before I lost patience and rebooted. I would say the average time is 1.5 minutes. I know that my GPS receiver is working properly, because I immediately have signal when starting other GPS applications (Including my copy of MapPoint).
sinister99 is offline
Advertisement Sponsored links
Old 09-01-2007, 06:58 PM   #2
_
you state that the informtion under your user name is the information about your CarPC but there is no information under your user name. Please fill it out according to this thread: http://www.mp3car.com/vbulletin/anno...r-profile.html
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 09-24-2007, 12:49 AM   #3
S4Per's Avatar
i get the same result, and IMHO this bug should be a lot higher severity than 3!
Just dug into it over the last couple of days. I've had it take 15 minutes to get signal back (i.e. to get Nav not to show 'low signal from GPS') and if I exit SD and restart SD, it picks up signal right away.
I don't have log, but you have one above.
Navigation is a key piece of this software. If it's not up and running sub 30 seconds of a computer start or resume, it's useless. It worked better in the past.
S4Per is offline
Old 09-24-2007, 09:09 AM   #4
_
S4Per - one or two users reporitng an issue does not necessitate a higher priority on our developers list. Many times, when only one user is reporting an issue it's a user or a configuration error.
Only once bugs are reproduced by our team or are verified by other users can we re-evaluate and raise the severity level.
Jan Bennett
Old 09-24-2007, 11:47 AM   #5
S4Per's Avatar
Thanks Jan, I understand. As I mentioned, "IMHO" :-)
S4Per is offline
Old 12-10-2007, 02:15 PM   #6
_
Please retest with the latest release and report back with your findings: http://www.mp3car.com/vbulletin/1151243-post25.html
Jan Bennett
Old 12-10-2007, 08:22 PM   #7
Car totaled, and mobo destroyed....will be a while before I can test
Old 12-10-2007, 08:38 PM   #8
_
thread closed then.
Jan Bennett
Closed Thread
Problem: Standby, Hibernate, can only resume once wuzzaap123 General Hardware Discussion 2 08-30-2006 11:19 AM
hibernate issues being slow toxsickcity General Hardware Discussion 3 08-15-2005 12:00 PM
m10000 doesnt always resume from hibernate fasternfaster General Hardware Discussion 0 11-29-2004 03:21 PM
Voice activated navigation for routis! 0l33l PowerVoice 352 10-03-2004 03:39 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 02:16 AM
