navigation: paramater does not exist - 1.0.9.8
What version of StreetDeck is this bug report for?
latest version (1.0.98 I beleve)
Please give a basic description of the issue here.
Yesterday I went to turn on map smoothing for my nav system in streetdeck. I selected the checkbox and also selected the google earth checkbox. I then saved my settings and loaded the nav module. It said initializing Nav, then a windows error message comes up with an error, and won't let me close it. The error says "The paramater does not exist" or "The parameter is incorrect" (cant remember exact phrase) and puts the PC into a loop. I keep hitting ok, and it keeps beeping. The only way to get out of it is to reboot the system. I know it's not the nav receiver, as I can run the nav software that came with the system and it sees it, and gets satlock right away.
Streetdeck Bug Reporting Process
If no, please describe your system here.
dell laptop (pentium 4, 2 gig processor with 384 mB ram)
Streetdeck **BUG** Definition:
Reproducible error using all Streetdeck supported hardware correctly.
This process was designed to eliminate the confusion of reporting a bug with Streetdeck. Bugs will only be fixed if they are listed in the StreetDeck bug forum and contain all the required information. Do not expect a bug to be fixed if it is not listed or does not contain all the relevant information. The job of StreetDeck tech support as it relates to reporting bugs is to duplicate issues and confirm that they are in fact bugs and not simply configuration errors or unsupported hardware. Please help by providing accurate information.
Please provide any relevent information regarding the issue you have encountered.
I have since unchecked all options in nav config that originally created the probelm and the problem still exists. The error only appears when I load the nav module. I can load the music module and everything is fine. I know that the gps is working becuase the speed is displayed in bottom right corner of music module.
