Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 12-12-2007, 09:41 PM   #1
tek818 is an unknown quantity at this point
NAV doesn't work - 1.1.1.0
What version of StreetDeck is this bug report for?
1.1.1.0
Please give a basic description of the issue here.
NAV doesn't work
Is the system that is listed in your CarPC specs under your username the same system where you encountered this bug?
No
If no, please describe your system here.
Asus R2H
1GHz Pentium M
1.25GB RAM
80GB SATA HD
GPS
Vista Home Premium
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the isse you are reporting.
Open SD, select "Navigation"
Please provide any relevent information regarding the issue you have encountered.
Downloaded SD trial, then purchased and registered. Once receiving the NAV disc, I uninstalled the previous version; then installed the version on the DVD, then upgraded to 1.1.1.0. SD loads fine, then once I click "Navigation", I get the following error message: "Navigation failed to initialize properly. Is the navigation data installed?" The only option is to then click "OK", which takes you back to the home screen.
EDIT: ms streets & trips was previously installed/uninstalled
Here are the error logs:
WARNING: CNAVController::InitializeMappoint_Help - Could not find mappoint communication window! This usually means the StreetDeck Mappoint Add-In is not properly installed. Attempting to reregister.
INFO: UV_ExecuteAndWait - Waiting for process ("regsvr32.exe" /s "C:\Program Files\StreetDeck\MappointAddin.dll")...
INFO: UV_ExecuteAndWait - Process ("regsvr32.exe" /s "C:\Program Files\StreetDeck\MappointAddin.dll") completed.
INFO: Message Box:
Navigation Failed!
Navigation failed to initailize properly. Is the navigation data installed?
WARNING: CAVInputDeviceManager::EnumerateInputDevices - Could not find audio device id for device (@device:cm:{E0F158E1-CB04-11D0-BD4E-00A0C911CE86}\DirectSound: Speakers (SoundMAX Integrated Digital HD Audio))!
INFO: Message Box:
Initializing...
Please wait while the media player initializes.
WARNING: UV_GiveWritePermission - GetFileAttributes - The system cannot find the file specified. (ERROR=0x00000002)
WARNING: UV_DeleteFile - DeleteFile - The system cannot find the file specified. (ERROR=0x00000002)
WARNING: UV_DeleteFile - Failed to delete file (C:\Users\Adam\Documents\StreetDeck\wplC908.tmp)!
INFO: Message Box:
Initializing...
Please wait while navigation initializes.
INFO: Message Box:
Navigation Failed!
WARNING: CPlugin::Init - Invalid plugin (FMMouse.dll)! Function (SetComPort) not found while initializing dll!
WARNING: CPlugin::Init - Invalid plugin (RadioFaker.dll)! Function (SetComPort) not found while initializing dll!
OnPreCreate - Initialization time 0.219 / 0.219 seconds.
WARNING: UV_GetUpdateList - The system cannot find the path specified. (ERROR=0x00000003)
Window / Direct3D Create - Initialization time 0.016 / 0.297 seconds.
WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = 6
WARNING: UV_GetFileList - The system cannot find the file specified. (ERROR=0x00000002)
WARNING: CPluginBag::GetPlugin - LoadLibrary - The specified module could not be found. (ERROR=0x0000007e)
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Users\Adam\Documents\StreetDeck\Plugins\Input\ InputG35SWC.dll)!
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Users\Adam\Documents\StreetDeck\Plugins\Input\ InputPhidgetsEncoder.dll)!
WARNING: UV_GetFolderList - The system cannot find the path specified. (ERROR=0x00000003)
tek818 is offline
Old 12-14-2007, 06:56 AM   #2
update: just did fresh install of vista and the first app i installed was streetdeck. still no navigation... Calling support tomorrow.
tek818 is offline
Old 12-14-2007, 09:42 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
This does not appear to be a bug but rather a support issue. Please do not use the bug reporting forums to handle support issues. No harm, no foul, just please be aware in the future.
Thread closed.
Jan Bennett
RedGTiVR6 is offline
Closed Thread
Stealthy surfing at work? e_z_street Off Topic 15 10-07-2009 03:30 AM
Does FluxMedia own rights to our skins? justintime CF Skins 13 09-03-2006 08:22 PM
NAV bug? Resume navigation does not work S4Per StreetDeck 2 07-07-2006 05:28 PM
Allbrite and controller work with RCA but not VGA alti LCD/Display 22 01-05-2005 01:47 PM
Will the Toshiba LTM10C021 (10.4") LCD work ok with an AD2 (standalone) controller? pooshda LCD/Display 4 11-18-2002 09:59 PM
