Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 12-13-2007, 07:33 PM   #1
Nola111's Avatar
Nola111 is an unknown quantity at this point
Streetdeck Crashes everytime the volume overlay is used - 1.1.1.0
What version of StreetDeck is this bug report for?
1.1.1.0
Please give a basic description of the issue here.
Is the system that is listed in your CarPC specs under your username the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the isse you are reporting.
1. Start SD.
2. Start playing a song in the Music module.
3. Press the volume button in the upper right
4. Press the vol. button at the bottom
5. Wait
6. Volume overlay does not disappear on its own (it should, correct?)
7. Regardless, try and do something in the music module while the volume 8. overlay is still open.
8. If that doesn't cause it to crash, go into Enhancements.
9. Enable them, and play with levels while music is playing
Eventually, SD will crash.
Find attached the 4 crash logs... it happened to me 4 times before I threw my PC out the window of my car.
EDIT - for some reason, the forum will not let me attach files. Please get the crash logs here:
http://www.mediafire.com/?9x1sgksxmyk
I'm about done with SD with all these crashes and bugs.
Please provide any relevent information regarding the issue you have encountered.
Nola111 is offline
Old 12-14-2007, 09:40 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
closed - I moved this to the new bug reporting system. Please track it here: http://www.mp3car.com/vbulletin/tracker.php?itemid=21
Jan Bennett
RedGTiVR6 is offline
Closed Thread
Enhanced Volume Control XxAndyxX Software & Software Development 15 06-12-2007 09:25 PM
Can I redirect volume buttons? IntegraKarim FP FrodoComm 0 03-03-2006 01:21 AM
NEW VERSION RELEASED - XM and PHOCO Added - GPS IMPROVED!!! reddeath30 Mobile Impact 56 12-29-2005 06:06 PM
DVD volume much quieter than mp3 volume bosskong Centrafuse 1 02-26-2005 11:53 PM
Re-mapping of volume controls: Winamp Vs System volume Alric MediaCar 11 02-11-2004 11:59 AM
