Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Old 03-04-2007, 03:36 PM   #1
FLAC is for flaccid
parksgm's Avatar
parksgm will become famous soon enough
SD crashes unexpectedly after resume from hibernation.
What version of StreetDeck is this bug report for?
1.0.6.3
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Streetdeck crashes when "Create route" button is selected after resuming from hibernation. This doesn't happen after every resume, but always happens after a resume.
Sometimes, SD will allow one new route to be created, but attempting to create a second route causes the crash. As far as I can tell, the tray app is killed too, because SD doesn't offer to restart itself.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline
Old 03-17-2007, 12:47 AM   #2
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
Please run with -verbose and send your logs when this occurs.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline
Old 04-10-2007, 11:54 AM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Any updates on this parkgsm?
Jan Bennett
RedGTiVR6 is offline
Old 04-11-2007, 02:55 PM   #4
FLAC is for flaccid
parksgm's Avatar
Well, yes and no.
I have enabled verbose logging, but haven't posted the file yet. Sorry.
I pulled my computer inside to do the 1.0.8.1 update (and some other stuff), so I'll get those logs posted soon.
parksgm is offline
Old 04-13-2007, 08:59 AM   #5
_
I'm gathering from a previous post elsewhere that this is no longer an issue?
Jan Bennett
Old 04-13-2007, 11:29 AM   #6
FLAC is for flaccid
parksgm's Avatar
Doesn't seem to be, but then again I've only had the update in the car for a couple of days now (unlike some *ahem* beta testers I know of...but I digress).
Consequently, I haven't been through that many hibernate/resume cycles, (probably a max of 10) since installing the update, and the problem previously occured most frequently when the system was resumed after sitting for a long perioid of time (overnight).
So, while I THINK this is no longer a problem, it might still be... In any case, I won't be heartbroken if you close the report.
parksgm is offline
Old 04-13-2007, 11:32 AM   #7
_
Issue closed.
However, if there is still an issue, please PM me and I will reopen it for you.
Thanks!
Jan Bennett
Closed Thread
SD crashes when pressing volume ctrl or play ryguy StreetDeck 14 07-13-2006 10:19 AM
Change Resume hibernation screen solution. but needs help neon_eddy WinNT Based 15 01-30-2006 08:17 PM
Resume time from hibernation with EPIA M/B's toxsickcity Software & Software Development 6 09-22-2005 01:32 AM
Lilliput (sometimes) fails to display on resume from hibernation captain_jim1 LCD/Display 3 05-11-2005 02:00 PM
Problem with interrupted resume from hibernation with XP Mastiff General MP3Car Discussion 1 01-25-2005 05:46 PM
