The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Bug Reports
Closed Thread
Thread Tools Display Modes
Old 03-04-2007, 09:44 PM   #1
S4Per's CarPC Specs
S4Per's Avatar
Vehicle: 2002 Audi S4 - Not quite stock
My Photos: (0)
DCR: Enable accessing most buttons on each module via a single (arrow) key
What version of StreetDeck is this bug report for?
1.0.6.3
Please give a basic description of the issue here.
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
yes
If no, please describe your system here.
Please provide any relevent information regarding the issue you have encountered.
Using keyboard only.
As it is, you must use all four arrow keys to navigate the various buttons in SD. For example, on the home screen, there are 3 rows and 3 columns of buttons. If the center most button is highlighted, you must use the up arrow if you want to highlight the center button in the top row, or the down arrow if you want to highlight the center button in the bottom row. If you click the right arrow, you will be at the right most button in the center row. Clicking the right button again, will result in no action.
Desired functionality: one should be able to use a single button to continuously circle through the buttons on any one module, or set of buttons on any one module. In essence this is tab stop functionality.
Example 1: on home screen, you should be able to use the right arrow key (for example) and by turning it repeatedly, cycle through all of the available buttons.
Example 2: On the music screen, you may want to split this functionality into two sets of tab stops: one for the menu options on the left (select music, search, etc.), and then require a TAB button - or any other button, to get into the list of currently queued media. If that media 'set' is then selected, you should be able to cycle through all songs in the list in a looping fashion also.
S4Per is offline
Sponsored Links
Old 03-05-2007, 07:08 PM   #2
FLAC is for flacid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Both good points. These should be user-selectable options, if possible, as they would add significantly to the ease of keyboard use.
User selectable because I don't want/need to repeatedly cycle all options with a single key at the present time and would prefer to have the focus highlight "stop" if there are no more buttons above (if hitting the up arrow) the current button as it is now.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline
Old 06-20-2007, 11:39 PM   #3
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
please retest on 1.0.9.8 and report back with your findings.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline
Old 06-25-2007, 08:18 AM   #4
_
My Photos: (73)
Jan Bennett
Old 06-28-2007, 09:34 AM   #5
_
My Photos: (73)
Thread closed due to a lack of follow-up from the original poster. 8 days have passed without a response.
If the original poster would like to have this thread back opened, he/she may do so by going to the 'Thread Tools' drop down box at the top of the thread. If the Original Poster does so, the Original Poster must post information in response to requests for additional testing. Else, the bug report will be closed again.
Jan Bennett
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
Left arrow key has 'back' function associated with it S4Per StreetDeck Bug Reports 9 03-17-2007 01:06 AM
NaviVoice v.6 RELEASED! 0l33l PowerVoice 28 10-11-2004 12:34 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
