Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck F.A.Q.
Old 07-20-2007, 10:36 AM   #1
_
UNBOUND error when trying to access Navigation / Navigation Failed Error
Many times this error is caused when a previous version of Map Point or Streets & Trips was installed.
If you are going to be using the StreetDeck DVD to install StreetDeck, you will need to completely remove any previous installs of Map Point or Streets & Trips from your system. Failure to do so will yield errors when trying to access the navigation module.
A Mappoint Diagnostic Tool has been created that will help diagnose where the error is coming from and allow the mappoint control used for StreetDeck navigation to be reregistered. You can download the tool from:
http://www.streetdeck.com/update/uti...pointTest3.zip
To use the tool, extract the executable to the Program Files\StreetDeck directory and run MappointTest.exe. After it runs it should show a verbose log of what happened when the navigation control tried to initialize. Warning messages may be shown even if the tool successfully runs. If navigation is installed properly a small map should show in the upper left corner. If the map is not visible, you should press the registration button and rerun the tool. If the map still does not show up, press the registration button again and copy the contents of the log output and paste it into a new thread created in the StreetDeck sub forum on mp3car.com. Be sure to include how you installed navigation, i.e. from the StreetDeck DVD or by installing mappoint and any other steps you may have already tried to diagnose your problem with your post.
If you run this tool on Windows Vista, you will need to run in as an administrator for registration to succeed.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 10-23-2007, 08:23 AM   #2
The Parameter is incorrect
This seems like a similar problem to the one above. I had navagation working fine just a few days ago and then out of no where whenever I click on navagation i get the error "parameter is incorrect" with an ok on the message. I can click ok as many times as I want but the message will not go away. I have to <ctrl> <alt> <del> to close street deck. I had this exact problem about a month ago and finally reformatted the hd. I could not fix the problem after uninstalling both street deck and map point and deleting all directories and searching through registry and removing any entries that seemed related. and the error never went away. I will try the fix for the problem mentioned above and post my findings.
davisj is offline   Reply With Quote
Old 10-23-2007, 09:22 AM   #3
_
http://www.mp3car.com/vbulletin/stre...avigation.html
Jan Bennett
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 03:29 PM
Failed to load control 'Flash' error on load Vinci Road Runner 2 04-25-2005 12:35 AM
EWF + Windows failed to start successfully error message knubile WinNT Based 6 01-01-2005 01:25 AM
Voice activated navigation for routis! 0l33l PowerVoice 352 10-03-2004 03:39 AM
