Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck F.A.Q.
Old 01-23-2006, 01:12 PM   #1
Raw Wave
god_of_cpu's Avatar
StreetDeck Software Dependancies (Download Links)
StreetDeck requires a number of required and optional dependancies in order to work properly. When purchasing a complete StreetDeck system, all these dependancies are already installed with the system. You will only need to download and install these if installing StreetDeck on a non-preconfigured system.
NOTE: The bold items in the list below are required, all others are optional, but may limit the functionality of StreetDeck if not installedIt should also be noted that if your machine already has Map Point or Streets and Trips installed, it will cause problems when installing the full version of StreetDeck.
Both of these programs should be completely removed from your machine before installing the full version of StreetDeck from the DVD.
*Also, aside from Ffdshow you may need to install other codecs depending on the file types you are attempting to view.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Last edited by RedGTiVR6; 12-02-2007 at 07:50 AM. Reason: update WMP 10 to WMP 11 and info about MP and S&T
god_of_cpu is offline   Reply With Quote
Old 07-24-2008, 07:18 PM   #2
JasonMK's Avatar
Quote: Originally Posted by god_of_cpu View Post
[*]Navigation Data (Supports Microsoft Mappoint 2004 or 2006)
Just to clarify things, it would then be safe to install (or re-install) them (e.g. Mappoint) AFTER the full version of StreetDeck is installed, right?
_______________________________________________
All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
JasonMK is offline   Reply With Quote
Temporary Download links (destinator3.info down) zsh Map Monkey 0 01-21-2005 09:11 AM
where can i download gps software SRI Allan GPS 11 05-01-2004 01:19 PM
My numpad controlled custom MP3Car software - need your opinions PorscheMP3 Software & Software Development 7 04-11-2002 10:30 AM
