Premature StreetDeck Trial TimeOut
The StreetDeck trial edition will normally timeout after 30 days or 15 minutes of continous use. There are some things that can cause the timeout to expire early though.
Specifically, if you change the date on your computer (forwards or backwards) after the trial is installed, it may cause the trial to immediatly timeout.
If you delete some of the files in My Documents\StreetDeck directory, it will also cause it to expire immediatly.
Once the StreetDeck trial has expired, there is no way to reset or extend the trial period. You can, however, run StreetDeck in developer mode for an unlimited amount of time. Developer mode will let you experience almost all that StreetDeck has to offer, except audio and video will not be seen or heard.
