Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck F.A.Q.
Old 02-10-2008, 10:58 PM   #16
Kimota's Avatar
Kimota is on a distinguished road
Quote: Originally Posted by god_of_cpu View Post
You can change your hardware and it won't reset. You can even format and reinstall windows and it will still work. The only thing the code is tied to is your harddrive. If you pull the harddrive out that the code is tied to, you will need a new one. Other then that you can change everything else. You can even add and remove hard drives as long as you keep the one you registered on in the system. You can even add your hard drive to a different system and your code will then work for that system.
The system was designed with upgrades in mind, even those who upgrade on a monthly basis shouldn't have much of a problem unless they throw out thier hard drive every month.
I also don't believe this applies to solid state drives. I replaced my 2.5 notebook drives in Raid 0 with a single Mtron 2.5" solid state drive. After receiving a new registration code for the solid state drive I had and issue enabling AHCI, deleted the partitions using debug. After installing StreetDeck again my Hardware and check codes are no longer the same.
My Install
Kimota is offline   Reply With Quote
Old 02-11-2008, 07:53 PM   #17
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
StreetDeck was updated so that if StreetDeck can not get get a serial number from your hard drive, it will try other means to generate a unique code based on your hardware. If this happens, it will be more sensitive to hardware changes and can change with some hardware upgrades.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 03-01-2008, 07:45 PM   #18
johnjlopez is an unknown quantity at this point
order id
my order id number from mp3.com is only 5 characters but streetdeck requires 8. maybe im looking in the wring place. any help?
johnjlopez is offline   Reply With Quote
Old 03-09-2008, 08:08 PM   #19
oddvarr's Avatar
oddvarr is an unknown quantity at this point
Just to get this right
If you changed your harddrive 3 times, for various reasons, you have to call Streetdeck?
I suppose they are located in USA. I live in Norway. That would cost me close to an arm and a leg. But phone charge here is expensive.
Any chance of doing this online because of the costs?
If I donīt remember it. It never happened
oddvarr is offline   Reply With Quote
Old 04-03-2008, 06:09 PM   #20
grayvader's Avatar
grayvader is on a distinguished road
What do I do if I want to transfer my license to another person (i.e. sell it)?
grayvader is offline   Reply With Quote
Old 04-03-2008, 07:36 PM   #21
russoxley187 is an unknown quantity at this point
looks like we are looking at the same place...
thats funny....
russoxley187 is offline   Reply With Quote
Old 07-21-2008, 01:31 PM   #22
ASmods is an unknown quantity at this point
Have anyone found a KEY GEN or CRACK for Street Deck? Just kidding
I'm planning on running street deck on a Asus Eee 900 laptop, with 16GB solid state HD, would I have this problem if I re-install windows?
Also if I get 2 copies can I get a discount
ASmods is offline   Reply With Quote
StreetDeck License Transfer god_of_cpu StreetDeck 3 04-26-2008 09:59 AM
Streetdeck Now Available for Purchase god_of_cpu StreetDeck 46 01-02-2007 11:58 AM
Do I need an extra license to develop for StreetDeck? god_of_cpu StreetDeck F.A.Q. 0 09-19-2006 06:37 PM
Transfer License Zinjamaster StreetDeck 7 07-03-2006 04:59 PM
StreetDeck in Blogs Fiberoptic StreetDeck 2 01-16-2006 10:57 AM
