The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Skins
Thread Tools Display Modes
Old 11-25-2007, 06:07 AM   #1
DAE51D's CarPC Specs
DAE51D's Avatar
Vehicle: 2007 Scion tC
My Photos: (5)
Skin Editor from a novice P.O.V.
I attempted to build my first skin -- well, actually fix many of the flaws in the default skin.
  • What is with the big empty area in the editor with the "gears" background? Is something supposed to be in there otherwise it's just a huge waste of screen real-estate.
  • Is there no 'undo' command? There seems to be the little icons for undo/redo in the tool bar but they're always ghosted out? And the Edit menu doesn't list them either. This is my number one frustration, as a novice.
  • What's with the "T" button thing in the top of the screen of my skin? Where did that come from and why?! It's annoying. It just seems to be some new subsection, which is completely useless unless you actually are creating a new module or something. Otherwise you would just be editing or adding to existing modules. I can't seem to delete it either?
  • How come when I switch in and out of Design Mode (CTRL+D) there is some white outline of the last thing that was selected?
  • I ran the 1.1.0.6 .sdu update, and SD says that's the version, yet certain things that were fixed in this version on my G4 (such as the rating stars not staying highlighted, or the album picture in the bottom not staying highlighted) are NOT fixed in the dev environment.
  • How come certain controls can't be modified? For example the album area in the lower left. I click there, there is a big white outline thing with a horizontal and vertical line and some pixel locations shown. The properties doesn't let me change any value?! "CMusicTray > Invisible" to be exact. (it's the part that obnoxiously glows that I want to set the width to encompass the whole text too, and also set PreventFocus = true.
  • Why can't I edit module screens I don't actually have? Such as the Radio or Phone ones for example? This is silly. I have a radio in my G4 *IN MY CAR* not on my notebook computer where I'm doing all the skin editing! GRRR.
http://daevid.com/gfx/tC
Infill G4. StreetDeck.
Installed 09/17/07
DAE51D is offline   Reply With Quote
Sponsored Links
Old 12-26-2007, 07:57 AM   #2
Caelric's CarPC Specs
Caelric's Avatar
Vehicle: 2005/Infiniti G35 6MT Coupe
My Photos: (0)
Welcome to the frustrating, non-intuitive world of the SD skin editor.... On the other hand, it is somewhat easier to edit SD skins, as compared to other front ends.
Couple of answers, although you probably already have the answers, given the date of your questions:
The 'T' button on the top screen has seemed to appear randomly to me as well, although I have never had it appear in the finalized, non-dev environment skin, once I package it for use.
The white outline that is left behind sometimes seems to be some sort of dev environment bug; just save your progress, restart the dev eniornment, and it should be gone.
Undo would be nice, thats for sure!!!
As for editing module screens you don't have, I'm not sure why you can't do that; I have been able to, no problem. I don't have the phone set up yet, but I was able to edit a phone screen
2005 Infiniti G35 6MT Coupe Black/Black
Core Duo CarPC
CarDomain page
Caelric is online now   Reply With Quote
Old 12-28-2007, 09:16 AM   #3
StreetDeck Skinning Master
06TC_OWNER's Avatar
Vehicle: 2006/Scion/TC
My Photos: (0)
The 'T' button is supposed to be a 'template' button. For different sections you are supposed to be able to apply the template to that entire section and it will adjust the things you moved/resized...
View my current SD Projects:
06TC_OWNER is offline   Reply With Quote
Old 12-28-2007, 10:41 AM   #4
Caelric's Avatar
My Photos: (0)
Huh, learn something new every day!
Core Duo CarPC
CarDomain page
Old 07-31-2008, 06:49 AM   #5
JasonMK's CarPC Specs
JasonMK's Avatar
Vehicle: 2007/Saturn/VUE
My Photos: (35)
I know this is an old post, but things seem to be the same. I also have a G4 in my car and can't seem to access to edit any of the radio module on my laptop. I tried -fakedata on the outside chance it might help, no luck...
_______________________________________________
All installed, and ready for visitors. Infill G4 in a 2007 Saturn VUE
JasonMK is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 182 06-24-2008 02:33 AM
Mauri RR skin mauri RR Skins 122 12-06-2007 09:50 AM
Find a List of Available Skins Here! ThunderStick RR Skins 0 10-17-2007 06:28 PM
IG3 Will not stay inside of the SKIN - opens in itsown Window..... dtragic GPS 4 11-29-2006 01:57 PM
IG3 working with FREEDOM SKIN - Will not Embedd Right... dtragic GPS 2 11-21-2006 03:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
