The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Skins
Thread Tools Display Modes
Old 02-04-2008, 07:59 PM   #1
neiljames's CarPC Specs
neiljames's Avatar
My Photos: (0)
How do you make the buttons Transparent?
OK. I have watched the tutorial video and began to play in developer enviroment mode. I have changed the background image and simply want to make the buttons on the start page transparent or mostly see through. Can someone give me direction. I look forward to the results.
EOC Memeber expanding the Horizons!
neiljames is offline   Reply With Quote
Sponsored Links
Old 02-04-2008, 09:38 PM   #2
TheSin's CarPC Specs
TheSin's Avatar
Vehicle: 2001/Ford/F-150
My Photos: (1)
All buttons are made with PNGs, PNGs support multi layer transparency, so it should all be done in the files you used to build a button. I use Photoshop, photoshop you just change the layer(s) Opacity, and utilize a transparent canvas to start with.
TheSin is offline   Reply With Quote
Old 02-05-2008, 10:15 AM   #3
Kimota's CarPC Specs
Kimota's Avatar
Vehicle: POS 05/Mazda/RX8
My Photos: (0)
You can also use infraview its a free image editor then change the .png file to a solid color then save as transparent. Or you can just simply download a skin that already has transparent buttons (hint, hint mine does) and change your background pic to what ever you like.
pssstt
Kimota is offline   Reply With Quote
Old 02-05-2008, 05:12 PM   #4
neiljames's Avatar
My Photos: (0)
That sounds good to me. Where can I download yours from. I am willing to take a hint!
Old 02-07-2008, 09:59 AM   #5
Kimota's Avatar
My Photos: (0)
Here ya go its a link for the skins sticky RX8 skin
pssstt
Old 02-07-2008, 02:05 PM   #6
neiljames's Avatar
My Photos: (0)
Thanks I can't wait to check it out!
Old 02-07-2008, 02:09 PM   #7
neiljames's Avatar
My Photos: (0)
Move a button to anothe page.
I know I am crawling but I know with this forums help I will be running soon.
I want to move the more button from the front module onto the setup page keeping its function the same. Than I would like to change the label to say shortcuts. What is the easiest way to move an existing button?
Old 02-08-2008, 10:25 AM   #8
TheSin's Avatar
My Photos: (1)
I use cut and paste between modules.
Select the button cut it from that module and paste it in the one you want.
Old 02-08-2008, 11:23 AM   #9
neiljames's Avatar
My Photos: (0)
Cut and Paste
I tried that and it does not seem to work. I would place it in design mod, click on the button so it is highlighted and I tried ctr x, and than ctr v...nothing
I also tried using the cut and past under edit. Still nothing. What could I be missing?
Old 02-11-2008, 10:38 PM   #10
Raw Wave
god_of_cpu's Avatar
Vehicle: 2003/Infiniti/G35 Sport Coupe
My Photos: (0)
You need to make sure the module or overlay you want to paste into is highlighted in the tree control. The easiest way to do this is to selet another panel in the desired module you want to paste into.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
god_of_cpu is offline   Reply With Quote
Sponsored Links
Old 02-11-2008, 10:53 PM   #11
polo6979's Avatar
Vehicle: 2003 BMW 325ci Sport
My Photos: (14)
Thanks for this... I was about to ask the same thing
BMW 325ci Sport in the works
95% done
Here is my project.
PCI - PCMCI Controller for sale.
polo6979 is offline   Reply With Quote
Old 02-11-2008, 11:49 PM   #12
neiljames's Avatar
My Photos: (0)
Glad to know I am not the only one. I will try and let you know what I bump into next.
Thanks.
Sponsored Links
vB code is On
Trackbacks are Off
How-To: Relocating Screen Buttons Altimat Fabrication 41 11-07-2007 03:48 PM
Starting to make a Skin, need some help please Slickrick2000 Newbie 5 03-10-2006 09:46 AM
next to-do: chassis front pannel buttons, need your suggestions mpattonm Fabrication 7 02-05-2005 06:41 AM
Where to get black Lilliput buttons Quattro LCD/Display 2 09-14-2004 07:49 PM
Make winamp transparent churnopol Software & Software Development 3 06-21-2003 06:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
