Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Skins
Old 02-04-2008, 08:59 PM   #1
neiljames's Avatar
neiljames is an unknown quantity at this point
How do you make the buttons Transparent?
OK. I have watched the tutorial video and began to play in developer enviroment mode. I have changed the background image and simply want to make the buttons on the start page transparent or mostly see through. Can someone give me direction. I look forward to the results.
EOC Memeber expanding the Horizons!
neiljames is offline   Reply With Quote
Old 02-04-2008, 10:38 PM   #2
TheSin's Avatar
TheSin is an unknown quantity at this point
All buttons are made with PNGs, PNGs support multi layer transparency, so it should all be done in the files you used to build a button. I use Photoshop, photoshop you just change the layer(s) Opacity, and utilize a transparent canvas to start with.
TheSin is offline   Reply With Quote
Old 02-05-2008, 11:15 AM   #3
Kimota's Avatar
Kimota is on a distinguished road
You can also use infraview its a free image editor then change the .png file to a solid color then save as transparent. Or you can just simply download a skin that already has transparent buttons (hint, hint mine does) and change your background pic to what ever you like.
My Install
Kimota is offline   Reply With Quote
Old 02-05-2008, 06:12 PM   #4
neiljames's Avatar
That sounds good to me. Where can I download yours from. I am willing to take a hint!
Old 02-07-2008, 10:59 AM   #5
Kimota's Avatar
Here ya go its a link for the skins sticky RX8 skin
My Install
Old 02-07-2008, 03:05 PM   #6
neiljames's Avatar
Thanks I can't wait to check it out!
Old 02-07-2008, 03:09 PM   #7
neiljames's Avatar
Move a button to anothe page.
I know I am crawling but I know with this forums help I will be running soon.
I want to move the more button from the front module onto the setup page keeping its function the same. Than I would like to change the label to say shortcuts. What is the easiest way to move an existing button?
Old 02-08-2008, 11:25 AM   #8
TheSin's Avatar
I use cut and paste between modules.
Select the button cut it from that module and paste it in the one you want.
Old 02-08-2008, 12:23 PM   #9
neiljames's Avatar
Cut and Paste
I tried that and it does not seem to work. I would place it in design mod, click on the button so it is highlighted and I tried ctr x, and than ctr v...nothing
I also tried using the cut and past under edit. Still nothing. What could I be missing?
Old 02-11-2008, 11:38 PM   #10
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
You need to make sure the module or overlay you want to paste into is highlighted in the tree control. The easiest way to do this is to selet another panel in the desired module you want to paste into.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 02-11-2008, 11:53 PM   #11
polo6979's Avatar
polo6979 is an unknown quantity at this point
Thanks for this... I was about to ask the same thing
2003 E46 BMW
Lilliput Transflective, GM965 mobo w/ Processor
ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
Everything is for sale.
polo6979 is offline   Reply With Quote
Old 02-12-2008, 12:49 AM   #12
neiljames's Avatar
Glad to know I am not the only one. I will try and let you know what I bump into next.
Thanks.
How-To: Relocating Screen Buttons Altimat Fabrication 41 11-07-2007 04:48 PM
Starting to make a Skin, need some help please Slickrick2000 Newbie 5 03-10-2006 10:46 AM
next to-do: chassis front pannel buttons, need your suggestions mpattonm Fabrication 7 02-05-2005 07:41 AM
Where to get black Lilliput buttons Quattro LCD/Display 2 09-14-2004 08:49 PM
Make winamp transparent churnopol Software & Software Development 3 06-21-2003 07:18 PM
