The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Skins
Thread Tools Display Modes
Old 04-25-2008, 08:21 AM   #1
Autockr989's CarPC Specs
Vehicle: 06/VW/GTI
My Photos: (10)
Binding customized links
I have took the plunge and started messing around with tweaking a skin I use religiously. Is it possible to create a "shortcut" button on the start menu for such things like "queued music" or "search music" so if i set the button to go right to the keyboard for the music search, I can bypass the music module folders and go to the subfolder.
Autockr989 is offline   Reply With Quote
Sponsored Links
Old 04-25-2008, 09:11 AM   #2
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
The best way to do it (and easiest), would be to create a gesture for it....
Settings
General options
Input options
Gesturing
Select music search module
draw the gesture you want to use
save
If you have voice commands active, "search music" will get you there too.
"Do not walk behind me, for I may not lead.
Do not walk ahead of me, for I may not follow.
Do not walk beside me either.
Just pretty much leave me the hell alone."
--unknown--
danielkh is offline   Reply With Quote
Old 04-25-2008, 09:23 AM   #3
Vehicle: 06/VW/GTI
My Photos: (10)
Settings
General options
Input options
Gesturing
save
You think it's time to take the plunge and get a mic. rather than use the button, especially if i'm def hooking up one onevoice connection when available.
Old 04-25-2008, 09:23 AM   #4
danielkh's Avatar
My Photos: (0)
Sorry, kinda forced my views on you there, didn't I?
Well, if you must have a button, I would suggest you load the SD trial version on a desktop if you haven't already. Open the streetdeck development environment. Then once in there, you can select the button you want to change, or create a new one (copy/paste works), and then you can change the module it controls. It's a major pain as there are idle, highlight, select, press options on the button, so like 4 or 5 overlays for each one.
--unknown--
Old 04-25-2008, 09:25 AM   #5
danielkh's Avatar
My Photos: (0)
Oh, oh, oh.......that's a SILLY question!
Just for bragging rights alone (showing it to your friends), the mic is the number one thing you should have. And with one voice plugin? You KNOW the first things your friends are going to do is "Play Michael Bolton". Heck, a $10 radio shack version on the sun visor works great!
--unknown--
Old 04-25-2008, 10:03 AM   #6
Vehicle: 06/VW/GTI
My Photos: (10)
I def want to do this. I've been contemplating it for a while, but do have some restricitons. Do you know if the griffin can be bound to set the press and hold to activate voice commands in SD?
I just wanted to work out other options before i do add another usb.
Some issues that have held me back:
Adding a powered usb hub in the front. need to figure out how to fit the larger hub and inverter. Most everything is hidden under my ashtray, but it is already a tight fit. So i'm still limited for room.
I still loose my xenarc usb touchscreen, even after running a direct extenstion cable to the computer. (this is really starting to **** me off.)
Old 04-25-2008, 10:07 AM   #7
danielkh's Avatar
My Photos: (0)
Griffin works perfectly for that app. That is what I used before going to the iMon.
Don't worry about usb. For now, go down to radio shack, buy the cheapest mic they have along with an extention cable, plug it into your mic in and run with it! You don't need an expensive mic for voice command. And if one voice doesn't release until July, you got plenty of time to shop and figure out configuration for a good one.
--unknown--
Old 04-25-2008, 10:10 AM   #8
Vehicle: 06/VW/GTI
My Photos: (10)
k good. when i fix my touchscreen issue, i'll be requesting help on binding that to the griffin. Just curious, that function gets set in the griffin settings? How would it now to active voice command in SD? i'm assuming SD settings have to be set as well?
Old 04-25-2008, 10:14 AM   #9
danielkh's Avatar
My Photos: (0)
It was pretty easy to do. I know I had to add streetdeck to the griffin program file.....
When you get to that point, remind me and I'll hook the griffin to the laptop and repeat it.
--unknown--
Old 04-28-2008, 09:34 AM   #10
Vehicle: 06/VW/GTI
My Photos: (10)
Calling all SD users.
I figured out how to get the search music function bound to a button and have placed it on the start screen. Is there a reason why it cannot search the music unless the media player is initialized. If the first thing I do is search for a song right from start up and this is assuming that no music has began playing yet, search results come back as "nothing found" If i start playing a song and go back and do the same search, bam music is found. When I go into th music module, I do get the pop-up that says "media player initializing" so I do know that the media player has to start-up before the search works. How can I get the media player to intialize from when I double click SD in windows? or how can the search work from the moment I turn on SD.
Sponsored Links
Old 04-28-2008, 05:09 PM   #11
danielkh's Avatar
My Photos: (0)
I would guess it's because SD uses the WMP (windows media player) and if the player isn't started (initializing), search wouldn't work. Just a guess, but it makes sense. Try this. Open WMP, then start SD, search without initializing music and see if you get a result.
You also might be able to put WMP in your startup folder if the above test works.
--unknown--
Old 04-29-2008, 08:10 AM   #12
Vehicle: 06/VW/GTI
My Photos: (10)
That does sound right. I stopped using things in my startup folder becuase I found the whole system to load faster if i opened SD up manually. I wonder if WMP would slow down the start up?
Sponsored Links
vB code is On
Trackbacks are Off
Dead Links - ARGGHH!! dark1 Suggestions/Comments 3 03-25-2006 06:09 PM
CarPC Links Directory itrends General MP3Car Discussion 1 04-11-2005 08:49 AM
Enhanced Weather Links for Web browser GizmoQ Centrafuse 2 01-22-2005 10:25 PM
Anyone else using del.icio.us for carputer links? revgeorge General MP3Car Discussion 0 10-10-2004 03:58 PM
New to the carputer, need links for parts. notoriouskeef Newbie 3 02-25-2004 12:35 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
