Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Skins
Old 10-18-2006, 09:37 PM   #1
Raw Wave
god_of_cpu's Avatar
Editing Sounds In StreetDeck
As of version 1.0.5.7, Streetdeck includes a number of sounds used for various interface events including gesture recognition and button presses. These sounds are stored under My Documents\StreetDeck\Sounds
If you wish to changes these sounds for a skin you develop, you need to place new wav files in your skin directory with similar names and they will be used in place of the default StreetDeck sounds.
Do NOT delete or modify any of the sounds in the default sounds directory without first moving them into your skin directory.
You may notice that some of the wav files in the default sound directory include a number in parenthesis at the end of them. This is a simultaneous instance count and is used internally by StreetDeck and not something you should worry about or use. When overriding the wav file with one in your own skin directory, do not include this number or the parenthesis.
For example, to overload the sound that is made when a button is pressed in your skin called "ExampleSkin", you should create a file called PRESS.wav in the My Documents\StreetDeck\UI\Skins\ExampleSkin directory. Note that the default sound file it is replacing is actually called PRESS(8).wav
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Skin Editing Tutorial Video god_of_cpu StreetDeck Skins 6 07-28-2008 11:10 PM
StreetDeck Input Plugins (Remotes, Steering Wheel Controls, etc.) god_of_cpu StreetDeck F.A.Q. 15 08-21-2007 03:46 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 01:01 PM
Streetdeck Now Available for Purchase god_of_cpu StreetDeck 46 01-02-2007 10:58 AM
Download StreetDeck Trial Version! god_of_cpu StreetDeck 43 05-04-2006 10:46 PM
