Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > StreetDeck Skins
Old 03-04-2007, 04:00 AM   #1
polo6979's Avatar
QWERT Layout....... UPDATED
I changed the modules around a little bit but I also corrected the QWERT keyboard layout. The search button is not hidden on this one.
Hope this helps someone out.
This is a zipped file... just extract it and run the sdz file.
Download Here
BMW 325ci Sport in the works
95% done
Front End - CENTRAFUSE ALL THE WAY!!
Here is my project.
polo6979 is offline   Reply With Quote
Old 03-04-2007, 04:06 AM   #2
P3D4T0R's Avatar
Sweet!!! Thanks a lot, sometimes lazyiness sucks, Iv been waiting for this.
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Comming Soon)
P3D4T0R is offline   Reply With Quote
Old 03-04-2007, 02:16 PM   #3
techy101's Avatar
Hrm, it crashes every time/way I try to install it...
Outside the dawn is breaking on the stage that holds our final destiny...
Dual In-Dash Screen Carputer Installed Check It Out.
techy101 is offline   Reply With Quote
Old 03-04-2007, 04:29 PM   #4
StaggRLee's Avatar
I can't even open the zip archive. WinZip says: "Not a valid archive".
StaggRLee is offline   Reply With Quote
Old 03-04-2007, 05:23 PM   #5
polo6979's Avatar
I dont know why its showing up as a ZIP file when trying to download it. I have it uploaded as a sdz and the properties of the link is sdz..... Looking into it.
95% done
Here is my project.
Old 03-04-2007, 05:40 PM   #6
StaggRLee's Avatar
If I use WinRAR instead of WinZip, I can open the archive (whether named as a .zip or .sdz) but get an error. The error is: "Unexpected end of archive".
If I dismiss the error dialog, I see a directory 'blaaa' and file 'version.txt'.
I still can't extract the 'blaa' directory which contains the skin elements though; WinRAR complains that the archive is corrupt or of an unknown format.
Thanks for the update. :thumbup:
Old 03-04-2007, 05:47 PM   #7
polo6979's Avatar
its not a compressed file at all... its just the packaged install file.
95% done
Here is my project.
Old 03-04-2007, 05:55 PM   #8
StaggRLee's Avatar
Actually a .sdz is just a renamed .zip file. The only difference I can see is that SD adds a "version.txt" file to the archive.
The file contains:
1.0.6.3
Skin
1.0
{00000000-0000-0000-0000-000000000000}
I assume this is to prevent compatibility issues with skins built with earlier versions of the SDK.
When I use the WinRAR 'Repair' tool I can extract all but one file: tabup_horiz.png
The error is:
..\..\My Documents\StreetDeck\UI\Skins\S60R_4\Orig_Modded\Q WERT\rebuilt.QWERT[1].zip: CRC failed in blaaaa\tabup_horiz.png. The file is corrupt
Old 03-04-2007, 06:13 PM   #9
polo6979's Avatar
I just installed it in my car just fine.... Here is a ZIPed file
Try extracting it and installing the sdz
http://www.funkytechmonkey.com/stree...DECK_QWERT.zip
95% done
Here is my project.
Old 03-04-2007, 07:18 PM   #10
StaggRLee's Avatar
OK that works. I can extract the .sdz from the .zip and then unzip the .sdz.
The skin pkg. for distribution/install is not working well for me with 1.0.6.3.
Thanks again!
Old 03-04-2007, 10:40 PM   #11
polo6979's Avatar
so it was a successful install?
95% done
Here is my project.
Old 03-04-2007, 10:52 PM   #12
Looks like M and N are backwards in the screenshot
sean335 is offline   Reply With Quote
Old 03-05-2007, 07:12 AM   #13
polo6979's Avatar
HAHAHAH!!!!... OOPS!
Its been fixed and has been updated.
95% done
Here is my project.
Audio CD Auto-play Playlist NOT updated layanto RR Bug Tracker 2 01-03-2006 03:40 PM
Mini-ITX Layout Specifications? Giuliano General Hardware Discussion 8 03-02-2004 12:07 PM
Speaker layout TLK General Hardware Discussion 4 12-26-2003 11:02 AM
New layout... Confused Mp3car Forum Suggestions/Comments 24 12-17-2003 12:59 AM
